![]() | Home > Technical > Viscous fan question |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5942 ![]() ![]() |
Don't sound correct to me.
I thought it should lock up the hotter it got?????????? Is it fully locked? Mine can be turned by hand and it is -2 here at the mo. May be worth removing it and see what happens to the MPG. Can't think one is required at these temps. Andy |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 ![]() ![]() ![]() |
Yes andy it's fully locked as far as I can tell. It's sucking through the grill like Gillian Taylforth in a lay-by
it was on a slip road Justin ![]() 1968 1/32 scale Britains 109 Pick up. |
Or even a trunk route ![]() |
If any of you guys would not mind checking in the morning to see if your does it I would be grateful. I can then ring the dealers and when they say "they all do that sir" I know what to say.
I just want to be sure it is not common to all Pumas Thanks Boy |
what about Gillian Taylforth Justin ? 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
You remember her, eastenders star caught giving her boyfriend a BJ on the side of the A14 and went to court and lost. ![]() ![]() ![]() ![]() I sure there is a lesson in there somewhere ![]() |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
mine does for a couple of minutes - all my vehicles in the past have also stayed on when started
Thanks It just worried me a bit as non of the TDi's I've Had/have do it. Cheers ![]() |
The classic tdi's and v8's did.
anyone removed it from their puma? thinking of doing it, as it runs all the time when doing over 70 |
My '07 Puma's fan was quiet on first startup in the mornings but the fan on my new one roars for a minute or two. Steve.
Mine is more or less staying on all the time now so I have booked it into the dealers. I hope it does not unlock when I take it in.
![]() If they don't change it then think I may just buy one and change it myself, anyone know how much they are? |
