Home > Puma (Tdci) > Indicators Don't Flash on locking
yorkshireman
Only a minor thing really but I've noticed my indicators don't flash when I lock my Puma and arm the alarm. Changed the fob battery, is this an option that can be selected or perhaps a fault? Anything to worry about?
Post #534060 23rd May 2016 7:15pm
Cat81
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Orkney Grey
Mine had that problem - was a simple fuse behind offside front speaker.
Post #534122 23rd May 2016 9:44pm
dgardel
Italy
read the owner manual.
not flash = remote battery low Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #534348 24th May 2016 8:46pm
yorkshireman
Hi, yes I've changed the battery in the fob. I'll see if it's a fuse.
Post #534358 24th May 2016 9:05pm
agentmulder
Kuwait
After a Fob battery change you may need to resync it:
>> Push lock 4 times then unlock
It'll be unresponsive until the unlock.
Hopefully that's all it is. Solved the bowel problem, working on the consonants...
Post #534365 24th May 2016 9:25pm
miker
My TD5 (Same alarm I believe) Only flashes 1 side, 95% of the time. Every so often, both sides flash. Both fobs are the same, and it's not a battery issue as it never flashed at all until I replaced the fob battery!
And yes, indicators and hazards work fine.
Post #534384 24th May 2016 10:04pm
agentmulder
Kuwait
Yip, same 10AS unit in TDCi and TD5.
The battery replacement thing seems random with my vehicle, I only discovered it the last time I did a swap, about 4 replacements prior never had the issue.
I also had an intermittent indicator repeater, that decided to operate with no apparent rhyme or reason, suspect it was a corroded connection...
Fuse sounds likely, if it's all of them.
Actually, should ask: do the indicator 'indicators' (in the dash) light up? Solved the bowel problem, working on the consonants...
Post #534393 24th May 2016 10:31pm
yorkshireman
Ok turns out the fuse under the drivers seat for the alarm was missing altogether, the previous owner had dogs so probably a simple solution to disabling the sensors but not the locking. Fuse in and all is working fine, indicators flash and alarm triggers as it should. Thanks for all the suggestions.
Post #537484 4th Jun 2016 4:29pm
