Home > Maintenance & Modifications > Rattling front drivers door
ChrisDefender
Hi all,
Fairly new to Defender ownership so still learning all the tricks of the trade.
My drivers door has just started to rub and rattle, well, more of a groan really. Mainly when turning right on slightly uneven surfaces. If I drive with the door open (on a private road obviously!) it stops, so its def the door. The hinges seem tight enough, I haven't tweaked anything else. Its driving me mad! Confused
Truck is a 2011 90HT.
Has anyone got any suggestions to help me sort it please?
Cheers.
Post #534007 23rd May 2016 4:33pm
mk1collector
Is the nylon cover still on the striker? Ray
My build thread
Post #534029 23rd May 2016 5:50pm
ChrisDefender
Hi,
Thanks for the reply. Yep, its still on there.
Cheers.
Post #534030 23rd May 2016 5:52pm
ChrisDefender
Hi,
Has nobody else got any suggestions as to what this could be, or similar experience?
Was rather hoping the wealth of experience out there could shed some light on it Sad
Cheers.
Post #534510 25th May 2016 12:13pm
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Could it be the door card making contact/rubbing with the seat box?
Post #534539 25th May 2016 1:15pm
ChrisDefender
Hi huffhuff,
Cheers, I had not even considered that one! I will check it later.
Thanks for taking the time to offer some help,
Cheers.
Post #534545 25th May 2016 1:27pm
ChrisDefender
Mk1Collector: I double checked the nylon sleeve and it is very worn. After hours of searching info online, it seems that I need to replace the striker, and many suggest the X Trouser one, so I have ordered one to see if that does the job. Thanks for your post and advice.
Seems like its a fairly common thing to happen, but it took me hours to find out the info Sad
Cheers.
Post #534870 26th May 2016 2:54pm
Grenadier
ChrisDefender wrote:
Hi,
Cheers.
I'm amazed nobody has yet suggested;
'It's a defender....' Whistle Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #534875 26th May 2016 2:57pm
ChrisDefender
Agreed, it is a Defender, but there are some things that are so annoying they have to be fixed Smile
Cheers.
Post #534882 26th May 2016 3:08pm
Maris Widgeon
England 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
What I do on my work truck when the door rattles,is to put a dob of general purpose grease on the door strikers.
This is only a farmer fix but does seem to work, the noise usually increases over a period of time as things get a little dry .
Have got a 2015 work truck and a 2007 90 of my own ,and it seems to work on both of them.
Nick
Post #534928 26th May 2016 7:01pm
Happyoldgit
Is it the door itself or something inside it?
If it's something inside then remove the door card, drip membrane and check the security of the various gubbins inside the door paying particular attention to the screwed / bolted inner panel.
If it's the door rattling in the door aperture: Pencil around the striker plate on the B pillar, slacken its securing screws and move the striker in a tad, secure the screws and see if the door rattles. Repeat as required. Steve.
http://forums.lr4x4.com
Post #534961 26th May 2016 8:58pm
ChrisDefender
Cheers guys, very helpful.
As soon as the new strikers arrive I will swap them over, and then do as you both say, appy a little grease anyway, can't do any harm, and then check inside the doors. I am going to be putting some sound deadening in the doors so they would have to come off soon anyway. Thanks also for the tip on mving the striker in a bit, as when I look closely, the door does sit slightly proud of the body so maybe does need moving in a little.
Cheers all Very Happy
Post #535092 27th May 2016 9:33am
Happyoldgit
Don't forget to mark the door pillar before you remove the old strikers as it saves having to readjust from scratch Wink Steve.
Post #535104 27th May 2016 10:33am
ChrisDefender
Cheers, will do!
I don't relish the thought of fiddling with those for hours trying to get them back in the right place!
Cheers.
Post #535111 27th May 2016 10:56am
ChrisDefender
Well, the new X Trouser door striker arrived today.
Fitted it OK, moved it in a tad after a bit of fettling and the problem is completely sorted Very Happy Very Happy
Plus, the slight draft by my right hip has gone too.
Mk1collecter, many thanks for pointing out the striker, being totally useless at this kind of stuff I would never had known about that, and Happyoldgit thanks for the advice of marking the old one first; top tip.
Cheers all.
Post #536214 31st May 2016 6:31pm
