![]() | Home > In Car Electronics > Where to mount CB radio - Puma dash? |
Butchers Boy Member Since: 10 Jan 2016 Location: Essex Posts: 426 ![]() ![]() ![]() |
Theater did you have to remove your sun visors to fit that? I cant see them in the picture
![]() The longer I live..... The better I was! |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3799 ![]() ![]() ![]() |
Best looking roof console I've seen,..ever. Checked out a couple of pages,there's 50+!!, of the corsetti site,....there is some beautiful stuff on there. Pickles. |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
No . I have my sun visors ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
![]() Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 ![]() ![]() |
I finally found a good spot for it. It's nicely out of the way.
![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1876 ![]() ![]() ![]() |
Cupboard, what model is that? Looks like a very discreet unit 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
It's an Allbrecht AE 6110:
http://www.4x4cb.com/public/item.cfm?itemID=1175 I've actually just had to clean my aerial mounting points because the SWR reading had gone from just over 1 (very good) to nearly the top of the scale (not good). |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
Anyone have one of these? Do you have to cut the roof lining to fit it? Thanks |
Yes ! This was mine " Corsetti Roof-Consolle " on my ex Puma 90 :
To fit the Corsetti Roof-Consolle need cut the roof lining ![]() ![]() https://www.defender2.net/gallery/albums/u...0Radio.pdf Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
Few more questions for you....
It seems you have to install the console first, then place the roof lining over the top of it... then put the trim around it. How did you get the measure,nets of where to cut, or did you take them after the unit was installed? Any issues once it was installed, rattling etc? A good mod for you? Thanks |
Markez79 Member Since: 27 Jun 2018 Location: South West Posts: 201 ![]() |
Hi,
Could this simply replace where the sunroof would be on an XS model? Thanks Mark |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18003 ![]() ![]() ![]() |
There is also this option: https://www.mudstuff.co.uk/mud-defender-roof-console-443.html
![]() ![]() My CB is in the cubby box, this is much neater up high and out of the way. Looked at the outback ARB, but that is just a large lump of plastic bolted to the roof, and you have to cut the visors, not a big deal. ![]() |
It's correct ! …… but 1° Remove the roof lining 2° Remove the central metal reinforcement under the roof ![]() 3° Install the console 4° With the console frame on the roof lining, mark the position of the console 5° Cut the roof lining around the sign of the console position 6° Place the roof lining over the top of it 7° Put the trim around the console
The electric wirings , and the CB antenna run under the side cover of the windscreen and under the roof lining ![]()
No . No problem for my console . For me it's a good console ! It is not very fast to fit . Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
