Home > Maintenance & Modifications > Advice: Socket head stuck on swollen nut...
RRUK
So, I went to remove the alloys from the Discovery 3 today and found that some of the nuts have the dreaded swollen issue under the caps..
I tried to persevere and tapped the 22mm socket head onto the first one to get a grip, but, once the nut was off, I can't get the socket off the nut. Evil or Very Mad
I've tried grabbing it in the vice and getting a puller on it but there's not enough of a gap to get the legs in.
Anyone got any advice?
I also found that the air powered impact wrench I have is pants. Not sure if it's the Aldi compressor or the wrench itself from the same range.
Should I get a decent air wrench or, buy a cordless one, if so, any recommendations?
Thanks chaps Thumbs Up 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #533273 20th May 2016 8:45pm
Spruce Pirate
Scotland 2013 Defender 110 Puma 2.2 HT Zambezi Silver
Take the socket off and clamp it in a vice. Find something that fits through the hole in the socket and smack it with a hammer until the stud comes out.
This assumes two things: 1 that you're going to replace the stud anyway, and 2 that no solution is worth while if it doesn't involve a hammer. Dirty Deeds - Done Dirt Cheap
Post #533274 20th May 2016 8:52pm
Happyoldgit
Appropriate size bolt in vice, wind nut on and you should be able to either wiggle the socket off or knock it off with a hammer & blunt chisel on the edge of the socket [rotating it bit by bit as you go]. A bit of heat might help. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #533275 20th May 2016 8:53pm
miker
I tend to just wind them back on to finger tight then wallop the socket off. Being careful not to wallop hard enough to damage the stud!
I also own (for a defender 27mm nut) a slightly larger socket that fits the swollen ones perfectly!!
Post #533281 20th May 2016 9:27pm
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
Re: Advice: Socket head stuck on swollen nut...
Bought one of these a few years ago and seem to work well. Has the advantage of being able to connect to a 12V battery.
https://www.machinemart.co.uk/p/cir13c-1-2...h-kit-12v/
Post #533284 20th May 2016 9:30pm
miker
Air impact tools are quite air hungry, so it's probably a combination of both. Also remember that they should only be used for undoing wheel nuts. They should be done up by hand, preferably a torque wrench. So many people over-torque wheel nuts. Defender is 95lbft. That's surprisingly little pressure required!
I have an 18V battery impact. It wont crack off wheel nuts or anything super tight, that's the breaker bars job. It is very useful for spinning things on and off, and on looser stuff, or stuff with nylocs/tight threads.
Post #533307 20th May 2016 11:29pm
agentmulder
Kuwait
Boil it in some water, pull it out with hands and drop on the ground immediately, or pull out with tongs and drop at your leisure.
If that doesn't work, freeze it and repeat the dropping it on the ground step, no need to tongs.
You're basically taking advantage of the dissimilarity of the two metals to your advantage ... Wink Solved the bowel problem, working on the consonants...
Post #533315 21st May 2016 1:17am
Caterham
Phew....
I did wonder what on earth you'd been playing at last night when I read the title Rolling with laughter
Post #533321 21st May 2016 5:53am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I hate the wheel nuts on my wifes disco 3. I even have some new ones as spares.
I have a old screw driver in with the jack now with the tip cut off and stick it through the socket. I then hold the socket and put the screw driver handle down and smack it on the floor to knock it out. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #533351 21st May 2016 9:11am
