Home > Maintenance & Modifications > Wiring Spots (no snorkel)
TACK
Looking at the option of getting some spots on the roof rack, most wiring options are where you guys have gone down or inside the snorkel, I do not have a snorkel. looked about a bit on the forum and I am sure this topic has been covered before, can someone direct me please Thumbs Up
TACK
Post #47328 3rd Dec 2010 9:08pm
Lorryman100
I have a snorkel fitted, but when I get a roof rack and spots thought I would go down this route of wiring them up as I would want to take the rack off when its not being used in the winter time:
http://www.entreq.de/products/electrical-e...ungen.html
TheBoy has some good threads on wiring up spots:
http://www.defender2.net/forum/topic3564.h...pot+lights
Post #47335 3rd Dec 2010 9:39pm
TACK
Cheers Brian, so long and short of it looks like I need to go through a panel somewhere to bring the cables in Confused
Post #47344 3rd Dec 2010 10:08pm
Lorryman100
Afraid so, then again you could always fit a snorkel. Believe Glynparry25 recently had one for sale Whistle
Post #47349 3rd Dec 2010 10:36pm
TACK
ummmmmmmmmmmmmm
avoided getting a snorkle as over confidence will see me getting wet feet Rolling Eyes Rolling with laughter
Post #47352 3rd Dec 2010 10:44pm
Lorryman100
Simply raise your feet up off the pedals thus avoiding the water and let the landys anti stall carry you onwards.......... Whistle
Post #47354 3rd Dec 2010 10:55pm
AndrewS
MAN up and get a snorkel you poof Thumbs Up 130's have feeling's as well you know Smile
Post #47359 3rd Dec 2010 11:26pm
Lorryman100
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Diplomatic as usual Andrew Rolling with laughter Rolling with laughter Rolling with laughter
Post #47361 3rd Dec 2010 11:28pm
TACK
oh hello Shocked
Don't really need a snorkel, want some lights though for night work. If i ever need to go into deep water I will call you as I will end up being one of those dick heads, I honestly dont see the need for one as the last time i was near water with you I think it was my right foot which had a problem not the depth of the water Rolling with laughter Rolling with laughter
Post #47363 3rd Dec 2010 11:47pm
leeds
Re: Wiring Spots (no snorkel)
TACK
With a roof rack and no snorkel you have various options. A watertight connector and go through the roof by the A pillar.
Alternative is use superseal connectors then take cabling along roof rack and then down the ladder and along the chassis.
Hope that makes sense
Brendan
Post #47365 3rd Dec 2010 11:59pm
110SEB
Without wanting to ask dummy questions, can I ask what needs to be done to auxiliary light wiring once it's inside the engine bay? Where have you guys wired it into. Is there a socket as there is for trailer wiring? Or is it a question of grafting on to current wiring?
I'd love to do this job myself, but i am a limited mechanical electrician! The limit of my skills was plugging in the trailer electrics and rewiring my old Sankey.
Thumbs Up
Post #48221 11th Dec 2010 7:43pm
leeds
First thing is to work out the current to your lights. Easy calculation from Current I = Power/12 volts. That is power per lamp and they are normally switched in pairs. This figure then defines the cable and fuse rating with an appropriate safey factor.
Most lamps will be switched via a relay which can be located in drivers seat box.
If wired separately from headlights then the spotlights are not legal for road use in UK
HTH
Brendan
Post #48224 11th Dec 2010 8:54pm
