Home > Maintenance & Modifications > WINCH WIRING
fekete
WINCH WIRING
Right Guys just got me new winch......What i'm after is some wiring diagrams of how you have routed the wires from the winch to the battery and what cut off switches you have used and where you got them from...and anything i should know or not do. thanks in advance Karlos Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #47277 3rd Dec 2010 5:13pm
BigMike
Go here -
http://public.me.com/studiomw
hit X9 - download, open, scroll down to page 7 Thumbs Up
Post #47291 3rd Dec 2010 5:57pm
fekete
Cheers Mike Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #47304 3rd Dec 2010 6:35pm
leeds
Ensure you use decent size power cables. 35mm2+
Isolator have a couple of possibilities. A 100 amp isolator is capable of handling up to 500 amps for short periods of time. OK for shall we say 'leisure' winching
A 200 amp isolator is about three times the price of a 100 amp isolator has 10mm studs cf 8mm studs on 100 amp isolator. It is about twice the size of the 100 amp isolator.
Have the 100 amp isolator on the 110 overlander and no problem with winching.
HTH
Brendan
Post #47310 3rd Dec 2010 7:13pm
fekete
Thanks Brendan, it will only be leisure' winching as you say.... not doing nothing to extreme.....will the standard battery cope with this or will i need 2 or anything else ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #47316 3rd Dec 2010 7:27pm
leeds
For 'leisure' winching you certainly do not need twin batteries. You might want twin batteries and might be able to afford them but needs and wants are different things.
If you double line you halve the load on winch and the line although double the time taken for winching. You also reduce the current draw as well.
A decent battery should cope if you keep the engine revs up. If it is going to be a long winch there is nothing wrong with winching for a couple of minutes then be stationary for a few minutes revving the engine to put charge back into battery. On a single battery what you want to avoid if you are solo vehicle is discharging your starter battery so that you can not start the engine if you stall it.
David Bowyer has some good videos on winching techniques. Worth watching.
Snatch block/pulley, gloves and tree strop are all useful.
Most useful thing is probably a bucket load of common sense. SAFETY comes first, learn safe techniques!
HTH
Brendan
Post #47323 3rd Dec 2010 8:12pm
TC
Re: WINCH WIRING
ooooohh, get some pics up sir!
After I sort out my gay stainless a bar a winch is likely to be my first big purchase. What did you go for?
TC
Post #47326 3rd Dec 2010 8:39pm
fekete
Thanks Brendan for the help and tips...i'm a little new to this sorry for all the questions i was hoping i could use my single battery...i have the snatch block / pulley and a tree strap...I'll also look at David Bowyer vids for a bit more help and understanding.
TC here is the winch i have its all sealed and pre wired so just need to connect to battery and a isolator
ore
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #47336 3rd Dec 2010 9:51pm
TACK
Bud, the cables you have might be a bit short to reach the battery, check it out before to start, nothing worse than setting the time aside on a saturday morning with good intentions and then finding out. Confused
I brought a goodwinch TDS and I needed extended cables to reach the battery box Thumbs Up
See if Goodwich can sort you out any of the extra bits you may needed, he will give you some stick for not buying his winch but I found Dave to offer outstanding service and advice Mr. Green
I took my cables running over the chasis (big cable ties) to the outside of the battery box and through the existing rubber gromet which goes in the box.
TACK
Post #47345 3rd Dec 2010 10:20pm
fekete
Nice one Tack, i think looking at them now they will not reach...Ill give Goodwinch a bell and see if he can sort me out with the right cables... Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #47347 3rd Dec 2010 10:25pm
TACK
No probs mate, go to 'new retail price summary' section and see page 6 for the defender kit...
http://www.dborc.co.uk/goodwinch/
i got mine chucked in with the whole winch deal. Seams a few quid but you get a fair few cable ties, the isolator plus the connectors are already on the cables to link the cables to the isolator and to link to your the cables already on your winch. You would normally need a proper tool to do get the connectors on the Heavy duty cable. Although I think you are in the profession anyway and you may be able to do it cheaper. this is just less hassle!
Bow down
Post #47348 3rd Dec 2010 10:34pm
fekete
Thanks mate will order that...thanks for the help and link as said you get the whole lot and no hassle....looks like K9 will be wiring that up for me as well as my lights....thank in advance Mal Rolling with laughter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #47355 3rd Dec 2010 11:00pm
jst
Goodwinch wiring kit will provide all you need to wire it in inc isolator that would be sufficient for your needs.
David does the wires long enough to go under the front gril then up over the n/s inner arch then back down into the battery box. I ran mine from the winch straight along the top of the chassis rail n/s and then into the battery box.
One battery is more than enough as Brendan pointed out for Leisure winching. i believe EP have a low current draw anyway, not quite as low as a TDS though! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #47390 4th Dec 2010 11:00am
K9F
Thought someone was fishing.....I caught the occassional glimpse of a fishing line and hook in front of me....bait wasn't very appetising though!
Didn't have anything whatsover on my Christmas agenda anyway!!!!! Rolling with laughter Rolling with laughter
If we have a heatwave consider it done!!!! Shocked If you go through life with your head in the sand....all people will see is an ar5e!!
Post #47391 4th Dec 2010 11:10am
fekete
Thanks for all the help Guys Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #47399 4th Dec 2010 1:10pm
