![]() | Home > Technical > Squeaky brake pedal |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 270 ![]() ![]() ![]() |
On mine (2011)its not the pedal but the two little grey switches.. a bit of lube, and it was cured! 1953 80"
1987 mini city e 2011 90" |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 697 ![]() ![]() ![]() |
Ditto to the switches - Bit of ACF50 solved mine.
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I took the little plate off the back of the brake pedal and lubed the shaft
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 ![]() ![]() ![]() |
Cheers lads - I'll try these. Always worth lubing
