Home > Technical > Defender Pulling & Vibration
Ayrshirelandy
Has anybody had issues with their Defender pulling to one side? I had the four wheel alignment carried out and pulling since this being carried out, though dealer stating within tolerances. A vibration is also present between 50 - 60 mph and at which speeds the pulling becomes worse. Any help? 2015 Defender 110 XS Utility Santorini Black, sawtooth alloys, steps and so much more...........
Post #529166 4th May 2016 9:42pm
Do you mean pulling to one side all the time, under acceleration or braking?
Post #529168 4th May 2016 9:45pm
Forum member CR had an issue not sure if it's fixed
Post #529182 4th May 2016 10:23pm
Ayrshirelandy
Pulling under acceleration, braking makes no difference. It is running to the left which gets worse as you accelerate 2015 Defender 110 XS Utility Santorini Black, sawtooth alloys, steps and so much more...........
Post #529198 4th May 2016 11:09pm
Wondering if it maybe a halfshaft, possibly OSF?
I'm no expert to comment on symptoms or possibilities but if there was a lack of drive one side for whatever reason that'd cause a pull to one side I'd have thought.
If it was tracking or wheel related I'd have thought it would be heading one way or the other constantly.
If it's pulling to the side under load / acceleration I'd have thought it's the drivetrain somewhere.
Quite possibly on the side it's pulling towards.
Post #529200 4th May 2016 11:19pm
