Home > Technical > Slight 'ping' or 'clunk' from rear
Page 2 of 2 <12
Stacey007
I've tried to have a luck under the car with a bar to see what play is in stuff... nothing obvious.
I have also been trying to replicate it more
Generally 1st gear just literally starting off there is a clunk, on setting off in 1st gear. I've also noticed it does it slightly in 2nd and 3rd. If I'm doing around 2000 revs in 3rd and just take my foot off the accelerator its more of a rattle (like a heat sheild is touching the exhaust)
In anything higher than 3rd and quicker than say 30 mph its much harder for me to tell its doing anything?
Any idea
Post #529611 6th May 2016 9:01pm
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
Sorry I can't resit this one...you live in the UK own a Land Rover and have a few "pings" and "clunks" - given all the other things you face like staying in or leaving the EU is this not a very minor irritation? More seriously the clunk is more likely the rear ball joint and or bushes .... that rattle is heat shields and they need some tweeking - confirm it is worse on certain road conditions when the vehicle is loaded? My dealership here in SA knows the problem well!
Post #529642 6th May 2016 11:16pm
agentmulder
Kuwait
Might sound like a bit much for many, but if you're this way inclined it's not that hard to mount a camera down there, process of elimination ... Solved the bowel problem, working on the consonants...
Post #533127 20th May 2016 8:42am
Stacey007
Not a daft idea at all I thought about that with my No Pro camera.
Its booked in soon for a service so I hope it should be easier when on ramps to look at what it could be.
Smile
Will report back
Post #533145 20th May 2016 10:10am
Stacey007
OK so it went for all the fluids and filers changed this morning.
That's all sorted but although he replicated the sound he didn't have time to locate it (they shut half day) so need it back.
Its basically seems 1st / 2nd 3rd up to around 40 Mph if you lift off the power or the car is under load (say going up hill) and use the power it Rattles like a heat shield but from the back.
If you Knock it out of gear when its doing it, it seems to go better?
Clutch biting point, revs etc the way it drives is all normal?
Any ideas,
The 'ping' at parking speeds is a UV joint and although play in it its OK? so up to me if I want them to change it?
Post #533470 21st May 2016 7:14pm
agentmulder
Kuwait
If you've got play in a UJ, keep a reasonable eye on it. Those things only get worse and never experienced it but from all accounts worst case failure can be quite 'uncomfortable'.
In my case my clunk is the rear half shaft/flange connections...
You've removed the wheel and popped the caps to check? Solved the bowel problem, working on the consonants...
Post #533536 21st May 2016 9:38pm
Stacey007
OK so my truck has been in the garage, to have this looked at.
Also it was pulling to the left slightly so asked them to check that, then the service,
New Engine oil
Gearbox Oil
Transfer Box
Diff front and back
Air filter
oil filter
Fuel filter
Rang them today and the noise apparently cured, it was as some of you said the prop shaft rear UV joint
and the brake pulling to left was seized caliper
Hopefully when I get it back it should feel great again. The noise was very off putting and sounded like cans being dragged behind me Smile
Post #534332 24th May 2016 8:02pm
Page 2 of 2 <12
