Home > Maintenance & Modifications > NAS LED
foxhound
United Kingdom 1995 Defender 110 300 Tdi SW Alpine White
NAS LED
I want to upgrade the external lights on my 110 Defender 300tdi to LED without having to drill new holes in the bodywork.
I understand that RDX make some easy fit plinths for NAS LEDs that use existing holes.
Can anyone help answer the following questions:
Do NAS LEDs mounted on these easy fit plinths overhang the body thus making the light vulnerable to damage?
How do RDX NAS LEDs compare to WIPAC? Or should I be looking at other brands altogether?
Will Wipac and/or other brand makes of NAS LEDs fit onto RDX plinths?
Thanks for any help and advice you can give. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #528284 1st May 2016 11:50am
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
is there a reason why you prefer the NAS lights? (they are bigger than standard 73mm lights on defender.
I use wipac leds. they are exactly the same size and same fittings as the original. so no holes need to be drilled
the kit even come with a relay.
Post #528288 1st May 2016 12:02pm
foxhound
I just like the size and visibility of NAS - it's more murky here than in Sydney (where I spent 12 years)! 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #528297 1st May 2016 12:51pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I wouldn't worry about the visibility and size issue of NAS LED over Wipac. A couple of friends and I have the Wipac kits fitted with the relay for the indicators and they will not be missed. If following at a sensible distance the lights are stunningly bright. Brake lights are almost painful to look at directly. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #528302 1st May 2016 1:34pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Just a heads up if you fitting to a 300tdi.
I have just fitted some Wipac LED's from Mud UK,side lights brake & indicators,with the special relay.
When I plugged them in, none of the indicators or front side lights would work. Surprised
After a bit of research on t'interweb.It turns out that some,300tdi's were wired the wrong way round for these lights,so the wires for the LED's needed to be changed around.I cut the wires from the LED's to the socket as supplied & wired them the oposite way round. Thumbs Up Thumbs Up Thumbs Up
Marc
Post #528305 1st May 2016 1:57pm
Screbble
Yes I've also heard that the wiring 'changes' at some point - TD5 production? It's effectively reversed....
With regard to the size of the lamp, as others have said you needn't worry as the standard size LED's really outperform the incandescent lamps by a long shot. Thumbs Up
I've fitted std size RDX LED's all round (plug and play) and it makes a world of difference.
If you're changing the indicators, get yourself the special really which will prove invaluable if you intend to tow. Thumbs Up
Best of luck and I hope all goes well.
Post #528449 2nd May 2016 9:10am
foxhound
Marc
thanks for the warning Marc 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #528462 2nd May 2016 10:16am
foxhound
is there any consensus re wipac or rdx or mobile centre or le perei? the prices vary hugely. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
Post #528463 2nd May 2016 10:18am
Mdm
you get what you pay for....
wipac nas ones on mine, no problems in 12months and they have had a few dunkings
no issues with the relay either.i have spare relay just in case in the spares box
Post #528659 2nd May 2016 10:12pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Had RDX on my previous Defender for 2yrs before selling. No issues.
Put the Wipacs on my new Defender 3 weeks ago, they seem brighter to me and time will tell how reliable.
Post #528671 2nd May 2016 11:00pm
jimbob7
I fitted rear NAS,for practical and cosmetic reasons,they throw out so much more light light,even with standard bulbs.The Wipac units I have leaked till I sealed them (Captain Tolleys).I also had to modify the hole for the stop/tail light so they didn't overhang.Also be aware that your rear wheel hits the stop/tail light when you open the door,I "fixed" the check strap so I have even less door clearance now Neutral .I'll probably fit a wheel carrier at some point.Shud also add,I do prefer the standard indicator,sidelights at the front. Pov.spec,ftw. 2006, 110,TD5.
Post #528771 3rd May 2016 12:49pm
