![]() | Home > Maintenance & Modifications > rear strip between tub and windows rusting |
| Motoberg Member Since: 01 Oct 2015 Location: Aberdeen Posts: 104
Click image to enlarge As per the title, is this an easy fix or does the roof etc have to come off to replace or repair it properly ? See the orange arrows in the photo Cheers |
| CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729
Unfortunately it's not an easy fix to do properly. You could try to fix it in place, it may look nice for a month or two, then it will come back, guaranteed.
Solution is the roof and side panels come off, then remove the capping, repair and re-install. Best bet if you are thinking of the future is to galvanize it, along with the rear capping. I'm a little OCD when it comes to dealing with rust, I like to deal with it one time and know it's not going to come back. it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
| Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026
Yes bare metal underneath
http://www.defender2.net/forum/topic10467.html |
| alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 729
You don't have to take the roof off.. The Landy is just big Meccano, basically loosen the headlining, undo the 10 mm bolts along the roof to side panel, plus a couple more over the rear passenger door, pop up roof, then undo the 13 mm nuts just above the capping(3). Disconnect seat belt anchor point (17mm) then you can pop the side panel out. Yaks an hour first time, 15 minutes second time!! Then drill out rivets that hold the cap on and lever them off, replace with fully painted ones ( shocking!) re-rivet and to quote the Haynes book of lies, refitting is a reversal of that... Draught excluder seals work just as well as any overpriced L/R part, I tiger seal the joints for belt and braces. It is a satisfying job to do.
Cheers Alex 98 300 tdi 90 project 88 200tdi project soft top 96 disco 1 jap import 79 911 sc 08 130 double cab utility |
| Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 697
Here is a link to loads of info on it from when I changed mine on my previous defender. I just did one at a time, with about 18months in between.....
http://forum.landrovernet.com/showthread.p...indow-trim And a picture.... Click image to enlarge |
