Home > Td5 > C.V joints and swivel housings
kevinf
This may be a daft question but I'm due to change the swivel housings a and c.v joints on my 52 plate 110 and obviously to swivel housings are full of one shot grease but do I also need to pack the c.v joints with c.v grease or do I use the one shot grease in side the joints, and have I seen a definitive swivel housing pre load setting topic on this site, I cant find it now
cheers kevin
Post #524983 18th Apr 2016 12:33pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I always rotate the the cv joint and add grease prior to fitting, there is a check to ensure you have the correct shimming, but I'm not sure off the top of my head. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #524985 18th Apr 2016 12:36pm
Lionel
Australia
Hi,
This is a well known topic, & there are some quite useful Youtube videos available which discuss the points you have mentioned.
This is a good starting point: https://www.youtube.com/results?search_que...l+bearings
You will find a lot of others related to this one.
Cheers,
Lionel
Post #525280 19th Apr 2016 1:59pm
jst
you can buy CV grease in 600ml carts for the grease gun, cheaper than one shot. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #525283 19th Apr 2016 2:35pm
jst
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #525287 19th Apr 2016 2:57pm
