![]() | Home > In Car Electronics > HELP PLEASE alpine removal |
Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171 ![]() ![]() ![]() |
I never bother. Just remove the entire switch panel and pop the radio out from behind. The panel is only held in by the 2 black bolts in the front. After that it clips out. also gives better access to the space behind for wiring etc.
Although to answer your question the release keys slot up either side (left & right) to push back some tangs. |
Google removing a radio gives you this.
mcl001 Member Since: 14 Sep 2015 Location: Pembrokeshire Posts: 31 ![]() ![]() ![]() |
Thanks - I will give it a go
