![]() | Home > Puma (Tdci) > A judder and a weird gearbox engagement/disengagement thing. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20804 ![]() ![]() |
How many miles have you done?
Could be the A frame ball joint but if you haven't done many miles I doubt it will be. Check the damper bushes especially the rear lower bushes. They have been known to cause a judder du to weight transfer. Just a couple of ideas. ![]() |
Augustus Member Since: 23 Mar 2016 Location: Carcassonne Posts: 86 ![]() ![]() |
Thanks Steve,
A frame ball joint was swapped. But will look into bushes. 11k miles ! G |
Eau02467 Member Since: 20 May 2015 Location: Glasgow Posts: 48 ![]() ![]() |
The judder could be any number of things but it shouldn't happen
The gearbox shouldn't crunch as you describe although the rev hang is normal for 2.2's. Given you have the crunch and judder I would personally drain the gearbox oil and check for any metal particles. If all is clear just refil gearbox with same oil, if not then investigate deeper. |
Thanks. 👍 😔
Was thinking of draining the gearbox oil and replacing. Good to know rev drop lag is a 2.2 thing. |
If replacing the gearbox oil follow the guide, it is not a level plug I.e you don't keep filling until you get a trickle of oil, you need to accurately measure the amount of oil you replace it with as described in the sticky guide at the top of the tdci forum
Yeah i saw that - v useful, thanks.
Bit gutted about the judder. G |
I'm struggling to see how your dealer has been very helpful - he's failed to diagnose a fault on your vehicle (I assume after multiple visits) and in the meantime milked the warranty process to keep the revenue coming into the workshop.
Would you be as happy with him if you had paid for all the work yourself? I'd be taking it to a separate dealer, speaking to the PR guy on here and seeing if JLR can't send a factory tech out to get a final resolution. I think you are suffering from the JLR equivalent of Stockholm Syndrome... |
A fair point.
My previous experience of dealers from merc to citroen and all manner in between (non JLR) has meant this pain in the ass situation has at least been approached openly and immediately every time i've reappeared there and then. Citroen would have just said 'computer says no' before looking. As for Merc... 😔 |
