Home > Tdi > 300Tdi Gearbox Relacement |
Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596 |
I had the Ashcroft high ratio mod on my defender when it was manual and really rated it. I would only do it if you have tuned the engine otherwise I feel it doesn't have enough power to pull the higher gearing.
6th Apr 2016 9:22pm |
Seabreeze Member Since: 23 Mar 2016 Location: Suffolk Posts: 47 |
Thanks, I am also fitting an Allisport double sized intercooler, so I have the chance to tweak the fuel pump. Will this be sufficient tuning to cope with the higher gearing?
6th Apr 2016 9:27pm |
I would have thought that should be fine to cope with it.
6th Apr 2016 9:29pm |
Many thanks!
6th Apr 2016 9:40pm |
