![]() | Home > Technical > Diff and gearbox oil drain plug questions.. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6027 ![]() ![]() ![]() |
On my 1999 Defender is a 1/2" square drive for the diffs.
Reusable and have never used lock compound on the threads. I think the gearbox drain is also a 1/2" square drive as is the transfer case drain and filler.. Not sure if this has changed on later models. The gearbox filler on mine is Torx T-55 I think 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
tomdaprince Member Since: 23 Feb 2015 Location: IJmuiden Posts: 54 ![]() ![]() ![]() |
Quirin,
Diffs is 1/2" female (Half duims ratel vierkant) Gearbox is hex for both filler and drain. Believe its 8mm (inbus). Plugs are reusable and conical (conisch) and therefore do not need any loctite or any other sealant. Specifications say fill gearbox not to hole but exactly 2.2L, I always fill to hole, as do all other LR specialists in NL. |
