Home > Puma (Tdci) > 2008 110 shocker change planned.
ARC99
Hi Folks,
I am Trying to plan a maintenance day tomorrow on the 110 and my mine has gone into old age mode. I was hoping that someone may be able to answer a couple of questions for me as the 110 is out for the night with S.H.M.B.O.
1. Are the rear top shocker mounts still a large washer and split pin or did they change to a large washer and machine bolt?
2. Is it still possible to pull the turret through into the engine bay without much trouble. ?
Thanks in anticipation. Don't make old people mad.
Richard
Post #520379 2nd Apr 2016 9:04pm
Rear top mounts are bolts, be careful to take note of washer orientation.
Front turrets you'd be best of scarifying the shocks by cutting off, especially if replacing.
Post #520383 2nd Apr 2016 9:13pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Don't know about the rear shocks on a 110, on a 90 nuts top and bottom.
Yes you can still pull the front shock out through the inner wing with the turret.
Post #520384 2nd Apr 2016 9:14pm
I use a large Boa for tightening rather than mile grips as it doesn't cause damage. Thumbs Up
Post #520387 2nd Apr 2016 9:27pm
ARC99
Well I have managed to change the steering damper and the two rear dampers from a full kit of 5 Bilstein shocks obtained from Alive tuning.
The steering damper was a breeze, the two rears put up a bit of a fight both taking off and installing the new set. I have never in 30 odd years had to take a club hammer to the bottom of a shocker to free it from the rubber bushes to get them free of the cup and I had to drift the new ones in from the bottom. A niece touch from Bilstein though is that the supply a new outer washer and unlock nut for the top hanger.
I'm leaving the fronts till I recover and have a good look at how to remove the plastic cover on top of the turret. Don't make old people mad.
Richard
Post #520612 3rd Apr 2016 7:36pm
ARC99
Why use a Boa, I just held the damper in my hand while I torqued it up to 27 NM Don't make old people mad.
Richard
Post #520613 3rd Apr 2016 7:38pm
Sorry, I mean removing or changing. I.e. If you changed bushes.
The plastic cover screws are a pain, when I did mine I cleaned the threads and where there isn't access to the head carefully undo them via the thread with some pliers.
That's what I did, and then when re-fitting fit them from the other way so you can access from under the arch.
IIRC, it's only the drivers side that you can't access the head.
Post #520622 3rd Apr 2016 7:48pm
ARC99
I can see one dreaded rusty self tapper on the driver side, I can feel the passenger side one but didn't go looking.
Easy way I found if changing the shockers is a large pair of Stilsons and a rattle gun for taking them off. More of an engineering approach when putting the new one on. Don't make old people mad.
Richard
Post #520642 3rd Apr 2016 8:24pm
Every man has his own way, I didn't have a windy gun to use for mine but when I did I did want to sacrifice to old shock anyway so wasn't an issue.
You shouldn't have much trouble with the screws on the cover, they are just a fiddly annoyance.
Thumbs Up
Post #520649 3rd Apr 2016 8:42pm
