![]() | Home > Technical > tyres |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
As long as the height profiles are same yes
landy101ambi Member Since: 02 Apr 2016 Location: edinburgh Posts: 5 ![]() ![]() ![]() |
thank you for your kind reply sir
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 ![]() ![]() ![]() |
Mechanically there is nothing to stop you
![]() However, for the sake of one tyre I'd replace both and keep it all nice and balanced - it'll also help to keep it more predictable during heavy wet weather braking (just MHO). |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1785 ![]() ![]() ![]() |
I agree with Riccarton. You say they're all 5 years old and getting worn, replace the pair on the axle.
Have a very, very good look at your tyres between the tread blocks and close to the rim. Looking for cracks.
Salt encourages degradation of tyres, as noticed you are in Scotland so assume they use road salt come winter time Brendan |
Horneteer Member Since: 10 Feb 2015 Location: Cornwall Posts: 60 ![]() ![]() ![]() |
Hi, I'd also go with Riccarton, but also check over the tyres as per leeds' reply.
If funds are tight you could replace the iffy half worn tyre with a new tyre to match the spare and put these two on the axle. Then put the good half worn on the spare, this way you only need to buy one tyre. |
thank you for reply guys its ok ive been down to Costco and got new Michelins fitted 7.50x16 xzl
Did you pick up some ear defenders whilst you were at it
