Home > Maintenance & Modifications > Setting up wheel bearings (New style)
Cetane
United Kingdom 2010 Defender 110 Puma 2.4 HT Galway Green
So one of the jobs on my list is to replace the wheel bearings. Ive got a copy of the workshop manual of which there is an excerpt below. I've read this through a few times in preparation for the job and don't quite understand it.
How can you measure endfloat of your existing assembly and then refer to the table? Surely you would have to use a standard spacer of "XYZ" dimension to measure and then based on the results select the correct spacer. If you use your existing spacer you could potentially have a value below zero for endfloat but be unable to measure it for obvious reasons.
Am I missing something here?
Thanks for your help.
Cetane
Post #520042 1st Apr 2016 5:38pm
Fatboy Slim
Wales
To tell you the truth, I've changed many wheel bearings with this type of setup and just put the original spacers back in with the new bearings. I had one once that felt too tight to me so ordered a slighter thicker spacer and that sorted that.
Post #520046 1st Apr 2016 5:49pm
Assemble initially with a purple (15.5mm) spacer in order to follow the wsm.
Post #520096 1st Apr 2016 8:03pm
Cetane
Makes sense Whistle
Post #520099 1st Apr 2016 8:09pm
