![]() | Home > Wheels & Tyres > Tyre wear - when to replace? |
or if the fronts are a different size to the rears... |
Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171 ![]() ![]() ![]() |
True.
Bit of a moot point though as you'd be a bit mental bolting dedicated rears on the front and vice versa. Re; cornering. It's more likely you'll find the limit of traction under braking out on the roads than any other dynamic phase. Especially unexpectedly eg. emergency stop. If you're finding the lateral (cornering) limit and its a surprise, then your driving manner might need some attention. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1790 ![]() ![]() ![]() |
News on the rear makes sense mostly because most cars are FWD and wear the fronts. Going Rear-Front-Bin means you always have fresh tyres all round, rather than never replacing the rears, just wearing and replacing the fronts, then 10years down the line having your 6+mm tread unchanged tyre blow out on you.
Or you could rotate your tyres and replace all 4 as a set...
In my daily I do enough miles that spreading the cost is nicer.
On the defender I'll probably do just that. But the mileage it does I'll end up replacing them on age rather than wear!! |
I can imagine.
Ive had a set of BFG ATs that were fitted new to one 90 and out lived the 90 that replaced it. That was in my youth though. Nowadays I'm a little more conscious of tyres aging. |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3659 ![]() ![]() ![]() |
I can remember a video being shown constantly on a loop in my local ATS a couple of years ago showing an Audi TT with new tyres fitted to the front, and then on the back, whilst cornering really quickly. ATS recommended that the new tyres go on the rear of the car. But an Audi TT is not a Defender. I expect a Defender cornering at that speed would not be worrying about which tyres had the better tread, but which body shop could repair the damage....... I would like to add that I was in ATS because the lease company who owned my company car insisted and that other national tyre chains are available
If course seeing as the centre diff is the most fragile you want as close a possible speed front to back, therefore you're best replacing one side. Given that the passenger side is always in the ditch and therefore needs more grip and is more likely to pick up punctures, the new tyres should always go on the left.
Ahem. I'd be putting them on the back myself, helps hill climbing if nothing else. |
Brilliant Cupboard!!!
Interestingly, I was asked to help move a caravan round a muddy field at the weekend. Not a lot of nose weight, it was the the fronts that let go first. Disclaimer: I am not proficient at pulling caravans across muddy fields. This experiment was not conducted in a controlled environment. I was running on 90 minutes sleep. And yes, I did use difflock after giving up without very quickly. |
Have you seen this video miker?
Start at about 1 minute. |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 ![]() |
Only by the ignorant. I'm not here for a fight, my interest is in people's safety. I do not refer to any of my data only that of the tyre manufacturers. Check their data, do some research for yourself. Tyre technology is rife with myth. I don't understand your comment regarding front tyres have a better compound. Ideally all four tyres should be identical in terms of traction, treadwear and temperature. You'll see these indices marked on the sidewalls. When talking of variances in grip levels tread depth is only part of the equation however it's generally accepted that all being equal a tyre with a greater tread depth will perform better, particularly as you point out in the wet. Heavily siped tyres will perform better in the wet but tend to overheat in the dry because the tread blocks are allowed to move too freely against each other producing friction. Nowadays, tyres are basically all radial ply, though cross ply and bias belted are still available, cord infrastructure is mainly, nylon, rayon and steel, I've not seen any fibreglass for some years, thankfully, because they could be lethal in the cold! When there was such a choice any mechanic could tell you what was compatable because this type of knowledge was commonplace, heavily legislated and controlled with both the C&U regs and the annual testing. Land rovers were of particular interest because then as it is now all driven axles have to have the same tyre construction. I've no interest in what owners do with their tyres unless im going to be the target of their uncontrolled mass spiralling out of a bend towards me. I started with nothing and still have most of it left! |
Yup. Worry not, I was in first low just above idle. As soon as the fronts started to slip I remembered that the little lever moves left as well. |
The odds of someone spiraling out of a corner and hitting you is far less than someone failing to come to a stop in a timely fashion. Who in their right minds drives on the limit of lateral grip on the highway???
Companies tell you to put new tyres on the rear to cover their backside. If the car swaps ends (Highly unlikely) you *Could* argue its down to tyre placement, where as if you fail to stop in time its gonna be a case of not leaving a big enough gap to the car in front. My comment about compound is that as a tyre ages, it's properties alter. It's usually becomes less compliant and delivers lower grip. If you take two identical tyres with identical tread depth but one is 2 years old the other brand new, then there will be a disparity in the grip they offer. Tread depth is only a concern in the wet, its the chemical properties of the rubber and contact patch that give grip. Think heat cycles in F1. |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1648 ![]() ![]() |
Great video...
Many thanks for that post. 'Lock the centre Diff'... ![]() |
