Home > Maintenance & Modifications > Creeping crack cure
Creeping crack cure
Okay, so after reading here about the Caltain Tolley's creeping crack cure I bought some the other day to give it a go.
It's currently due in the post at the moment.
I've bought it due to having a leak in the passenger footwell, a minor one but it is there.
I'm pretty sure it's the screen frame to bulkhead seal on this occasion but could be wrong.
None the less it won't do any harm to use this stuff.
Is it a case of having a dry day and running it right along the whole seal? I believe it's clear so you can't see it.
Post #518302 27th Mar 2016 9:37pm
shaggydog
Best way to describe it is pva glue in water.
It drys like a pva glue blob so use much less than you think and wipe up any excess quickly as it will leave a bit of a sticky mess otherwise.
Does seem to work well just don't expect it to plug a hole bigger than a fingernail width, it really is for very small cracks.
Good Luck Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #518306 27th Mar 2016 9:43pm
I see so a sticky sort of milk water then, I know what you mean.
It'd probably work well on the foam gasket then.
Certainly no holes! Shocked Rolling with laughter
Thumbs Up
Post #518310 27th Mar 2016 9:56pm
shaggydog
Exactly so Thumbs Up
Be ready with lots of clean non fluffy cloth to catch drips.
I made the mistake of using just some kitchen roll when I did the rear roof panel on mine and the more I rubbed the more it dried and is now a permanent dark grey from where the soot stuck to it. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #518315 27th Mar 2016 10:06pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Excellent stuff, cured a couple of leaks for me Thumbs Up Cogito ergo sum
Post #518318 27th Mar 2016 10:08pm
Wonder if running a line of masking tape just below would be worth it, leave it a bit then remove?
Obviously you wouldn't apply copious amounts.
Post #518322 27th Mar 2016 10:12pm
shaggydog
Shouldn't need it.
Best to drop it out into a container and then apply it using one of those cotton bud on stick the girlfriend uses for poking her eardrums.
It is very very runny Shocked
Does work well though Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #518326 27th Mar 2016 10:16pm
I've got some artists paintbrushes el' cheapo ones I could use. Bin it after.
Post #518327 27th Mar 2016 10:19pm
nitram17
I used a small eye dropper/pipette the ct fluid is quickly absobed by by the foam seal let it dry then coat two or three times...works a treat!
Post #518347 28th Mar 2016 3:39am
Screbble
I've used it Steve and it appears to do the job. It's good for the hairline cracks we sometimes get where the gutter meets the roof. Not much good for anything bigger than a crack though in my experience.
My footwell leaks originated in the area you are looking at. I don't know if it was the replacement of the faux hinge gaskets or sealing around the bolts and general area that cured it, but it's definitely bone dry now. I did carefully rub some silicon into the foam seal whilst the hinges were off - inside and outside.
I originally tried Captain Tolleys in that area but it didn't do it for me Crying or Very sad
Definitely worth a try though. I agree that you should definitely take care as it stains. Your idea regarding the masking tape should work.
Don't put it in your tea Thumbs Up
Post #518520 28th Mar 2016 7:13pm
I did think of the screen hinge blocks, however, I thought I would try this first.
Another possibility is the faux windscreen wiper hole rubber bungs.
No urgency to cure but I will get it sorted as soon as I can.
Post #518532 28th Mar 2016 7:45pm
Screbble
Hope it turned up today.
Best of luck.n Thumbs Up
For what it's worth, replacing the gaskets in the faux hinges took no more than half an hour and cost less than ten quid. You can also have a mooch behind the internal spacer/plate and squirt and seal to your hearts content.
Hopefully you won't need to Thumbs Up
Post #518742 29th Mar 2016 9:42am
jimbob7
I used syringes (couple of squid on eblag) for application of Captain Tolleys. Pov.spec,ftw. 2006, 110,TD5.
Post #518812 29th Mar 2016 12:59pm
It arrived today, can't do anything with it being so bloody wet though. Rolling Eyes
Hopefully shortly though, pity I just missed the dry spell!
Post #518873 29th Mar 2016 4:09pm
Screbble
How's your creeping crack Steve? Confused
The sun is shining up 'ere, so I thought you might be playing with Captain Tolley?
Post #519644 31st Mar 2016 5:22pm
