![]() | Home > Maintenance & Modifications > dinitrol cavity wax |
midlife Member Since: 15 Apr 2015 Location: Cork Posts: 122 ![]() ![]() ![]() |
Dinitrol 3125 in hollow sections. Chassis bulkhead door frames etc
Creeps well into small areas.
RichLech Member Since: 09 Nov 2015 Location: West Sussex Posts: 115 ![]() ![]() ![]() |
Just done mine last week. Filthy job but well worthwhile. Used 3125 cavity wax and 4941 underbody wax.
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
Why not read the pinned document - http://www.defender2.net/forum/topic10467.html NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
DOOFER Member Since: 07 Oct 2012 Location: Suffolk Posts: 412 ![]() |
thanks norman, but the guide isn't really what i'm looking for. it appears to be a detailed guide on the application of acf-50 which after using it to protect my gs1200 adventure, i don't really rate the stuff.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20964 ![]() ![]() |
ACF is a bit sticky and dirt clingy for my liking but it has it's place.
IIRC 3125 internals and 4921 as your underseal. You'll also need some rust cure, I used Kurust I'd recommend the internal you choose brown and externally back do you can tell which is which. There are some photos in 'my gallery' here somewhere. |
Fished out the pic for you of what I used:
![]() Click image to enlarge I'd recommend the following order: Clean and dry chassis Kurust application Stonechip application. (Adds protection and soundproofing) Internal wax application. Finally underseal application. Ensure brakes and exhaust are protected so mask up. Make sure you over buy for what you need amount wise, so you get a good job done and you'll always use surplus. I keep the 4921 permanently and spray new parts with it if changed over. I assume your using Aerosol? If so if you need any advice as to how many cans you'll need let me know and I can read up my previous posts. You'll find it a lot of work but very much well worth it! |
