![]() | Home > Maintenance & Modifications > Seat Rattle / Movement |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17868 ![]() ![]() ![]() |
Mine rattles in its track in the same way that you describe.
I have two solution which I use according to circumstances. Firstly, if I am alone, turn up the music. This covers a multitude of Defender-related noise problems and makes driving much less worrying. Secondly, I install SWMBO in the passenger seat. Even the relatively low mass of SWMBO stops the rattle but this approach does sometimes lead to other noises, some of which can be just as irritating! I am not aware of any sophistication or adjustment in the tracks themselves. It has been in my mind, when I get round to it, to see if the tracks can be forced further apart or together to make them stiffer, or failing that a biff with a brass drift and a lump hammer to tighten the track. In an ideal world there'd be an adjustable gib strip to take up any slack, but you probab;y need a Rolls for that. |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
Similar experience here on a 65 plate 110 xs utility with the premium seats, its driving me bonkers, the drivers seat rocks due to the runners having too much clearance, passenger side similar but not to the same extent.
Both seat frames are being replaced under warranty, technician at Guy Salmon Bristol didn't quibble, NormanD WE191 2015 110 XS Utility 2014 VW Caravelle 180 Executive |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 ![]() ![]() ![]() |
I had similar on a 65reg with standard XS seats. Passenger was fine, drivers noticeably rattley. I asked dealer to have a look when it was in for some warranty work and they changed it without any further questions.
Fish13 Member Since: 17 May 2015 Location: Aberdeenshire Posts: 71 ![]() ![]() ![]() |
Thanks guys - out of warranty so not able to go that route.
Has anyone taken one properly apart and fixed it? |
