Home > In Car Electronics > Switch basics - rear air conditioning
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
Hi Forum,
I have a rear air con in my 110 station wagon which is wired ti the instrument panel to tun on an off/fan speed.
What I would like to do is have dual controls - so i can be operated from the dashboard as well as the rear compartment.
basically OFF /Low/High control really. -
can the be done and if so what is best practice?
Post #514769 16th Mar 2016 3:55am
miker
It depends entirely on the system and how it's controlled. I assume it's an aftermarket thing?
Post #514789 16th Mar 2016 8:44am
itolond
yes aftermarket. common in ASEAN countries so I suspect there was some sort of factory doing these mods
Post #514841 16th Mar 2016 11:36am
mk1collector
Can't help with your switch question but could you post some pics of the setup and do you know the manufacturer? Ray
My build thread
Post #514968 16th Mar 2016 5:04pm
ajps72
2001 Defender 110 Td5 SW Chawton White
Re: Switch basics - rear air conditioning
I have an aftermarket rear Aircon, the termostat is at the back but the fan speed and the compressor switch is at the front, Y just extended the wires from the normal fan system to my location in front. The wires run below the "carpets" (that plastic things we have on the defender) Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #515156 17th Mar 2016 12:02am
