Home > Maintenance & Modifications > heated seats into a 300tdi
shazzy90
just fitted heated seats into my camper but not wired up ,I am seeking advice on how to wire them up,or anyone local after a few quid to do job, would be better
Post #513728 13th Mar 2016 12:07am
Alex1976
I ran a another heavy cable (100+ amps) from the battery live to an additional fuse box that I mounted between my front seats under my auto console.
I then put a pair of Carling switches in the dash and ran power from a fuse on the additional fuse box to the switches and then down to the seat connectors.
Saves trying to tap into existing looms and you know you have a sound set up with the correct loading for cables and fuses.
I also run my heated screen from this fuse box and my light bar.
All pretty simple to do
Post #513760 13th Mar 2016 7:16am
Screbble
Re: heated seats into a 300tdi
The diagram below may help.
It's 2002 onwards but you'll get the gist Thumbs Up
Post #513773 13th Mar 2016 8:54am
Screbble
Hopefully a much clearer pic.
Post #513774 13th Mar 2016 8:57am
