Home > Maintenance & Modifications > Raised air intake Snorkle Yes or No
Page 1 of 3 123>
Stacey007
OK, firstly and I may get shot down in flames for this I'm not after fitting this for what it can do purely for looks....
Now that's out of the way what's people opinions on these Snorkels? Interesting just asked a work colleague and they said it looks stupid, like a plastic elephants trunk.. I did ask I guess.
My cars black so I thought it would blend in better. Its this snorkel. Also could it be colour coded? or would the paint crack?
so yes its good or no its an elephant...
Post #511980 8th Mar 2016 1:03pm
RRUK
If you like it, do it.
Both of mine already had them on, like most bolt-ons, once it's been done it would look worse to remove.
I have seen one of these painted, but the problem with all plastic that is colour coded is the possibility of flex and the paint not being done very well to start with. Looks fine at first, a year or so later, not so good. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #511982 8th Mar 2016 1:12pm
gabe3105
As above, if you like it and want one, get one - its your money
The only caveat to the above is if it will limit your access to any garages/car parks you currently use which have height restrictions (I am assuming the snorkel protrudes above the roof line?)
Thumbs Up
Post #511985 8th Mar 2016 1:22pm
MartinK
Be aware that some people say it reduces power...
http://www.defender2.net/forum/topic31115....rkel+power
I have also read somewhere else that they can INCREASE power!!! Apparently by drawing cooler air!!!
Anyway - worth a read at the post I put above...
see also http://www.defender2.net/forum/topic21992....rkel+power Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #511986 8th Mar 2016 1:33pm
stanley
Yep do it! IMHO looks naked without one!
Post #511988 8th Mar 2016 1:34pm
Stacey007
^ is it any higher then the roof?
Doesn't look it, I don't have a roof rack so could make a difference if higher in car parks,
Thanks
Post #512027 8th Mar 2016 2:42pm
ericvv
The genuine Land Rover accessory version (very similar to the Mantec after market version) has a less high mushroom top air intake part than the Mantec after market mushroom top. I know the genuine RAI is not higher than the 2.03 meter standard height of the rear of a 110 SW. With the Mantec mushroom clearly a bit higher I don't know how many cm that adds. Ask Mantec I would suggest, they surely must have received that same question already a gazillion times.
Eric
Here a few pictures of the genuine. Compare with the Mantec after market mushroom version...
And Off Topic , here is the now infamous guy who is calling dad asking why did he not install a snorkel on their Puma Rolling with laughter
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #512033 8th Mar 2016 2:49pm
stanley
Just been out to check and it will be above the roof line by about 1/2 "
( guesstimate as don't have a measure to hand ! )
Post #512051 8th Mar 2016 3:26pm
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
the height restriction / doesn't apply to the lad.... with hair like that he wont be going under any low height restrictions Rolling with laughter
Post #512060 8th Mar 2016 3:41pm
Stacey007
Thanks stanley Smile
Post #512061 8th Mar 2016 3:43pm
Re: Raised air intake Snorkle Yes or No
Granted you are fitting it for looks - but you do not need to compromise on functionality. Get one that looks good and does the job.
In my opinion that one does neither.
Post #512082 8th Mar 2016 4:46pm
Stacey007
Which one does ?
Post #512083 8th Mar 2016 4:48pm
RRUK
Here's my first one on my TD5, it had "Safari" stamped on the side
And here is my current one on the Puma, it is a Mantec branded one. I prefer it. If you look at the side on profile picture it looks almost the same height, I can't see why Mantec would design it and make it higher than the car itself and therefore making it vulnerable off road and in 'situations'.
 2016 D4 HSE
Post #512125 8th Mar 2016 6:40pm
My Safari is in primer now, it's a sod to do due to the awkward shape!
Cant see any issues with flex as it's very rigid indeed.
Post #512139 8th Mar 2016 7:03pm
jst
which ones does the job? the safari ones as it comes with a different connector through the wing? you can fit the nugget or D44 solutuions to seal the Mantec one. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #512145 8th Mar 2016 7:18pm
Page 1 of 3 123>
