Home > Maintenance & Modifications > Fuel pressure regulator dripping
Telshe
England 2004 Defender 90 Td5 XS CSW Cairns Blue
Today after cleaning my TD5 (04) 90. There was a patch of oil under the centre rear o f the engine (it has a skid plate underneath so would not likely drop under where it is leaking) this patch was not your usual black oil stain. I had park on a different part of my drive therefore it was clean. I have been reading on the forums about Fuel pressure regulator leaking so l took off the plastic engine cover, started up the engine and looked around the back end drivers side and saw it dripping diesel l counted the drips at one every 3 seconds so let seems like a new one is needed. What l would like to know is would you advise me getting a Land Rover part or a other manufacturer or renew the rubber O rings. Any help would be most apreciated
PS. It is likely the original. It has 85 k on the clock
Regards telshe
Post #511743 7th Mar 2016 8:33pm
dorsetsmith
see link below is for disc 2 but it will give good idear ok
http://www.discovery2.co.uk/Fpr.html
two type of fuel regulator and gasket one for early heads and one for late heads later heads have extra pipe running from ruel regulator to the front the engine, replacement o ring need to be viton type i.e. ( diesel fuel torrent )
Post #511746 7th Mar 2016 8:47pm
