Home > Puma (Tdci) > LED reverse and fog lights wiring colours
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
Fitting these today along with rest of LED package. I know the LEDs are polarity sensitive so just to make sure before I crimp up the connectors............the lamps have a red and a white wire and the loom a black and a grey to each light fitting.....so....the blacks are the earth right?
Info on the light unit rear says the white is the negative so is that the earth? ie I connect the white to the black for the correct polarity??
Also which is the flasher relay (2.2 TDCI). Also also..........can I turn on the ignition with fitted LEDs and original flasher unit without damaging anything, as I want to identify the correct relay by 'feel'?
Post #511668 7th Mar 2016 5:35pm
Chocolate
United Kingdom 2004 Defender 110 Td5 XS CSW Bonatti Grey
hi Chipmunk
Found the same on my TD5, black on the car was negative/earth, White on the light Negative.
found out the hard way once i had crimped the first one!!
All worked after swapping it.
the number plate one took the longest. Very Happy 110XS CSW TD5.
Post #511671 7th Mar 2016 5:40pm
ericvv
Someone on here once gave a very good tip to test the polarity of LED lamps. Connect it to a 9V battery, and you will easily find out which of the wires is the positive. I did this when installing my Wipac LED number plate lamp.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #511678 7th Mar 2016 6:02pm
Eric - That may have been me. Laughing
Most people have got a 9v lying around somewhere!
Thumbs Up
Post #511688 7th Mar 2016 6:34pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
I'm not gonna lie I just put the ignition on and put the gear stick in reverse, touched the wires to the plug and which ever way they went to make the light come on is the way they were crimped. had no problems with them.
Post #511720 7th Mar 2016 7:51pm
chipmunk
Thank you all. I have the wiring sorted in my head, just need to know which relay to take out, Trial and error?
Post #511744 7th Mar 2016 8:42pm
Put hazards on and feel them, you'll soon know.
Normally 2nd from top left. Thumbs Up
Post #511747 7th Mar 2016 8:54pm
chipmunk
Steve I have installed and wired the LEDs, I won't damage them by switching on with old relay in situ?
Thanks
David
Post #511749 7th Mar 2016 8:58pm
Roy5695
nope, no damage, they will just flash a little quicker and the trailer light will flash as well with just the indicators.
Post #511750 7th Mar 2016 9:02pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
I've just fitted led's too. I changed the relay first of all (done by feel as suggested) and then put the new one in. Then after fitting each new unit, I put the 4 ways on to make sure each one worked OK and if has not affected the relay.
My only lasting problem is that I now have the trailer light on permanently...... Euro-Leafing to infinity and beyond.....
Post #511753 7th Mar 2016 9:06pm
Roy5695
Did you adjust the little knob on the relay? Turn that until the trailer light only flashes with the first indicator flash Thumbs Up
Post #511754 7th Mar 2016 9:08pm
^^^^ Change it with the engine running too, not ignition as the voltage is higher and more accurate.
Post #511757 7th Mar 2016 9:12pm
strang
Ah, thanks, will do that this weekend.......... Euro-Leafing to infinity and beyond.....
Post #512148 8th Mar 2016 7:22pm
chipmunk
Thanks for replies guys.......all done and dusted.
As already said, the number plate light took the longest.
Also had the polarity on side repeaters reversed but was very quick fix. Superb lights.
Post #512152 8th Mar 2016 7:31pm
