![]() | Home > Puma (Tdci) > Who has lifted the Puma? |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Cheers Mike i've looked into getting extra springs in the back but its been hard work as my local independent says you can only get them for the 110s.....So i just passed on the thought but knowing some one else has done this has made me think again the reason i'm asking is i tow everyday and could do with a little extra help back there i'm running discovery HDs on the back at the moment but with the weight i carry it could do with the extra spring...Thanks for your reply
No problem. If you can wait I'll be in Zagora in April so could always get some for you if I prep him first. But you might want to have a proper look and a drive of mine first.
Cheers Mike will most probably Go with that...also would like to see the set up.... i'm sure there will be a meet before then and we could sort something out as you will need the measurements.....one more thing is there any rattle or clanging from them ?
no rattle or clanging. quiet as a mouse. the measurements would be the same as mine wouldnt they? mind you i have polyurethane blocks on the base of mine, i think you'd need to take a look at it.
where in the country are you? |
Cheshire pm sent
Ok Fek's going to look at mine in person, but for anyone else interested:
front showing block ![]() rear double springs ![]() ![]() |
Thanks Mike...Ive been lurking on the net and found a company that could make me a set up....
http://www.gmesprings.co.uk/4x4_springs.htm NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Did you want leaf springs then
They say on there wab site that they will make one off springs ?
http://www.gmesprings.co.uk/spring_accessories.htm NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
yeah am winding you up
LOL Still up for the 24th so i can look and maybe go down your route.....but just been looking round to see what else there is
Hey if you can get it in england then all the better. In fact a mate of mine with a land cruiser has the same thing. I'll ask him where he got his done
Cheers Mike also found these guys
http://www.coilsprings.co.uk/offroad.htm NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Sheffield steel. Excellent
![]() I just swapped texts with my landcruiser mate. Turns out he had his done at the same place I did mine ![]() |
