Home > In Car Electronics > Tweeter Polarity
integrale
New Zealand
Tweeter Polarity
Just fitting a "Stage 2" ICE upgrade. Alpine subwoofer and replacement rear speakers fitted and all good. The last part of the job is replacing the front speakers and tweeters using the newly supplied crossovers. The tweeters don't have polarity markings. Each has a black and a black/thin white trace lead. Which is positive and which negative? Getting a bit knackered (hot sunny day) and don't want to make a simple/ silly mistake. Thanks
Post #511213 6th Mar 2016 6:20am
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
Hi integrale, in the UK usually the black lead with the white stripe would indicate the positive pole.
We use a lot of 12v devices in our line of work and when we have a prewired unit, we will use the white stripe as positive.
Can you RTFM to check? Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #511216 6th Mar 2016 7:12am
Ryderoo
I just quickly checked a Pioneer manual and it shows the white stripe as positive. Do you have the installation data?
 Cheers Simon
Post #511217 6th Mar 2016 7:24am
integrale
New Zealand
Thanks Simon. No manual came with the kit, and what info was provided doesn't help.
Post #511220 6th Mar 2016 7:58am
Ryderoo
No worries, hope the install goes well. Cheers Simon
Post #511225 6th Mar 2016 8:40am
