![]() | Home > Maintenance & Modifications > Air suspension on a 90 - has anyone done this? |
I can't say personally, but Nene Overland (who are miles away from you) have been advertising a kit in LRO recently.
http://www.neneoverland.co.uk/nene-news/we...-defender/ |
m33ufo Member Since: 19 Jan 2008 Location: Cardiff Posts: 1154 ![]() ![]() |
Had a reply from AccuAir....
"When it comes to the air springs and brackets that are specific to your vehicle, we don't have a kit available. This doesn't mean that you won't find a kit somewhere else in the market though and we will be happy to help you with your air management needs if you are able to locate the air springs." Not surprising I guess since it's an American company. |
That's awesome! I'll get an email off to them ![]() can be lowered to -110mm ![]() |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654 ![]() ![]() ![]() |
I like that! 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Would love to fit the full VB Air kit so I can get into car parks and lower te 130 a bit when I need tow a trailer.
Unfortunately, too expensive. |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Quite a lot have been retro fitted from classic range rovers have a goggle
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 ![]() |
How much does the VB kit come in at ?
Butchers Boy Member Since: 10 Jan 2016 Location: Essex Posts: 426 ![]() ![]() ![]() |
Have you been quoted? How much is too expensive ? 2010 Defender 90 HT The longer I live..... The better I was! |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Ach specialist vehicles do a full or part kit saw it fitted to a 90 a few weeks ago looked pretty good they advertise inside front cover of lrm most months
HTH 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Boyd Member Since: 11 May 2014 Location: Le Saint Posts: 172 ![]() ![]() ![]() |
Do a body swap onto a air sprung D3 chassis
![]() 2004 Santorini Black TD5 110 XS SW left hooker for sale! 2004 Alpine White TD5 110 left hooker (work in progress) |
It's been a while but if I remember correctly around 5,000 euro.
I spoke to the guy who advertised in lrm recently. Wanted 5-6k for a four corner kit fully fitted. He won't do a diy kit either. Waaaaay too much for what it is.
![]() ![]() ![]() The longer I live..... The better I was! |
Albion Member Since: 08 Dec 2014 Location: Oxfordshire Posts: 141 ![]() ![]() ![]() |
Received the following on the 3rd March from ACHSV, in response to a query generated from this thread, regarding my 90SW. Thought it would add to the conversation. Regards Hi Alan, The suspension system is fully automated and electronically controlled. You can adjust ride height from the handset inside the cab. For example "car park" lowers the car to its bump stops, around 90mm drop and from the on-road "sport" setting the car will raise 50mm to "off-road" setting. The system uses air bags made specifically for the Defender replacing the coil springs with a sensor on each corner constantly checking and adjusting ride height. The compressor fits between the chassis and gearbox on TDCI models. The system uses an auxiliary air tank mounted on the chassis to increase response time for the bags inflation. The compressor and tank both fit well up inside the chassis area so no, no restrictions there. Cost of the fitted system is £3957+vat The option of auto-level for stationary vehicle levelling for camping etc, £335+vat. We have a demonstrator available on a 110 Utility. We are based near Milton Keynes if you fancy having a go. |
