Home > Td5 > Disconnected pipes
Motoberg
Disconnected pipes
Can anyone enlighten me as to what these pipes used to be connected to ?
Passenger side of my TD5 engine bay
And while we're in mystery solving mode, what about these two thin plastic pipes (wire ? ) on the drivers side ?
They seem to connect to this device on the inner wing ( drivers side )
Cheers :thumbsup:
Post #506651 21st Feb 2016 1:07pm
dorsetsmith
top two air con compressor i would say look like compressor has been re moved !
bottom two EGR vacuum pipe work and EGR control sol on driver side wing EGR has also been removed
i believe previous owner of your 110 had intercooler upgrade and probably remove condenser rad and compressor to fit the up grade parts Question
Post #506654 21st Feb 2016 1:14pm
4RF RDS
The EGR pipes are just vacuum, you can take them out and plug the inlet on the solenoid. That was prettu shoddy workmanship. If you are going to remove a component, like the EGR remove it. The AC compressor has been removed but the pipework is very hrad and cumbersome to take out.
You put a plug on the solenoid like this.
Your EGR removal pipe should look like is. No hoses or wires dangling about.
That blue hose has been removed BTW Smile 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #506674 21st Feb 2016 2:21pm
Motoberg
Thanks Chaps,
Glad I've got all this Aircon gubbins at the bottom of my dash board then Laughing
I can feel a tidy up coming on Smile
Post #507002 22nd Feb 2016 3:43pm
4RF RDS
If the compressor is the only component missing from the AC you likely just need to replace it and charge the system..
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #507060 22nd Feb 2016 7:38pm
Motoberg
This is true as long as there's no leaks anywhere.
No rush though, It wont get turned on very often in Aberdeen Laughing
Post #507062 22nd Feb 2016 7:45pm
Fatboy Slim
Wales
I binned the A/C in mine. Frees up loads of passenger leg room (we don't require it much in Wales either Whistle )
Post #507070 22nd Feb 2016 8:17pm
dorsetsmith
time for parts sale Whistle
Post #507073 22nd Feb 2016 8:25pm
