![]() | Home > Technical > Which Nato hitch |
| mowcop Member Since: 03 Jul 2009 Location: Staffs Posts: 108
You might find your a bit low with the rear step fitted.
I have always found its best to have it high up, ideally on the rear cross member. |
| Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3898
Hello
When I looked into this I found the following. If you have a Sankey / penman that has a Fixed towing eye then you need a Nato hitch that can swivel, if the trailer towing eye moves then you need a hitch that is fixed. As I fitted a drop plate, I don't have to keep the hitch on as its not very pretty.... but very purposeful and will certainly put people off parking near the back It has a pin to lock it down when the trailer is connected and also a pin to lock the swivel mechanism, so I can either used it fixed if needed. This is mine, I think for it to be more useful I will need the spare wheel carrier to be raised slightly. There is a new bracket for this I have a link somewhere around 60. Click image to enlarge Usually some on e-bay or MOD auction sites. Or ask on here I got mine from a forum member |
| Brewstop Member Since: 28 Oct 2012 Location: South Oxfordshire Posts: 315
A nice shiney new NATO hitch from manufacturers
Click image to enlarge http://dixon-bate.co.uk/shop/gb/136-pintles http://dixon-bate.co.uk/shop/gb/pintles/23...coup-.html Sandy |
Agree with mowcop,
Its designed to be fitted to rear cross member where the 4 bolts are on an army Landy. They don't have a rear wheel so easier and them this gives them the right height. I think changing the tyres will help a little, however from your current tow height you need to be a fair bit higher? This is how mine sits with the Nato hitch in the position above. If the Tyre moves up a little I can get it slightly better. I'm happy with this as has to 'look' right and nose down a little is good for towing. Click image to enlarge on the original towing height, it looked like this.... Click image to enlarge |
| Leeroy Member Since: 01 Aug 2015 Location: East Yorkshire Posts: 261
mowcop
I have made a new plate that will make the hight just below the fixing holes in the crossmember will post some pictures when its painted. Stacey007 Thanks for the heads up regarding the rotating and non rotating I have seen your thread regarding the work you have done on achieving the hight. I think to get the best hight I will have to open the rear door to hitch the trailer because of the hinge on the he hitch. Brewstop thanks for the links I think there are a couple of the same brand on eBay but 7 ton and some with no towing capacity but detailed as land rover genuine ?? Many Thanks again Leeroy |
| Nick999 Member Since: 02 Sep 2019 Location: Cheshire Posts: 27
Here’s a bracket I had made out of 15mm stainless. I made a pattern out of MDF with hole centres marked up. Really pleased with it and it gets the right height for a Penman without losing the NAS bumper.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
^ nice workmanship that’s quite a piece of stainless steel
2008 SVX 90 2000 XS TD5 90 |
| Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1876
Nice solution Nick999.
I'd say get a rotating swivel which ever eye your trailer is fitted with as a rotating swivel can be locked in the upright position. Trying to hitch them with the door open can cause problems as the jockey wheel will likely stop the door closing afterwards. I've got mine fitted the same as Stacey007 and it's about as level as we'll get without doing something with the way the spare is mounted 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Thanks Sulisuli. The welder is a skilled guy. Never done stainless so left to those that can.👍
Rosco. I'm hoping I can work round it as I'm picking the trailer up today. Either that or I'll be driving home with rear door ventilation. 😉 |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18050
Remember that EITHER the pintle OR the lunette MUST rotate, but not both. If you're towing an early trailer with a rotating lunette the pintle must be fixed. If a later trailer with a non-rotating lunette, the pintle must rotate. Under condition of severe articulation the early type will lock and unless you are aware of this you'll destroy the lunette, your crossmember, or both (which is why the change to non-rotating lunettes came about).
The only pintle worth bothering with is the genuine DB article (beware there are nasty copies out there). Many Defenders do not require the pintle or the attachment to be type approved, but if yours was first registered on or after 29th October 2012 it does require full TA, and your only (legal) option is either to mount it directly to the cross-member or to use a DB slider mount, with a DB coupling. (Type approval for towing attachments was extended to include N1 Light Commercials from 29th October 2012). Remember also that if you have an older Sankey trailer (e.g. a narrowtrack) it MUST be modified to have a break-away cable which operates the brakes. Later trailers should already have this. Here, courtesy of forum member "Tiger", is a copy of the TA certificate for the DB pintle. Be aware that technically this only applies to pintles recent enough to have an "E11" sticker, but the design hasn't changed. Even if you don't actually need TA at present I suggest keeping a copy of this with your vehicle documents. The day will come.... Click image to enlarge |
Hi Blackwolf,
Great advice and thanks. The hitch is gen DB and rotates. The jocky wheel folds horizontal so the rear door wasn't a problem. Thanks for the TA doc I'll print it off and keep it. 👍 |
| v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 344
I have a Sankey Mk3 that I will be selling soon. If you want any height dimensions from that let me know?
Always useful to have a good fabshops number in your phone, like you I have a great guy locally
| All times are GMT |
