Home > Puma (Tdci) > Help with Puma injector fault
dannyc85
United Kingdom 2007 Defender 90 Puma 2.4 CSW Stornoway Grey
Hello first post on here although iv been lurking in the background for a while! I am looking for some advice on 2.4tdci injectors. My local Land Rover garage have said I have an injector stuck open causing white smoke from the exhaust. They are unsure which one it is but it is £450 per injector! Could I get 1 injector off ebay (£70) and just keep swapping them round until I get the faulty one? is there a way to code the injectors without an expensive diagnostics tool? Or would you recommend getting them sent away for refurbishment?
Thanks in advance
Post #505548 17th Feb 2016 7:13pm
Caterham
Firstly can you get an injector for £70?
Good with resolving - I presume you've had a go with the various injector cleaner additives on the market?
Post #505556 17th Feb 2016 7:36pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
Danny get your injectors tested mate I took mine to my local independent who tested mine found two faulty ones they was sent away and repaired for 90 pounds
Post #505569 17th Feb 2016 8:16pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
As said above, send/take them away for testing.
If you have a local Diesel specialist near you, they will undertake the work.
If not have a look online for company's offering this service.
I use PowerDrive in Portsmouth quite a bit, they are not local to me but have a good turnaround time. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #505582 17th Feb 2016 8:37pm
£450 each X four. Shocked
I use Millers diesel additive which should keep things clean, might this be of some help?
Post #505587 17th Feb 2016 8:43pm
dannyc85
How can they charge that much! £70 for a reconditioned one off ebay! Iv found a diesel specialist near me who will test them for me so il go down that route. Cheers for the advice everyone Thumbs Up
Post #505746 18th Feb 2016 10:19am
