Home > Puma (Tdci) > What do these fixings hold?
RichLech
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
So what do these rivet fixings hold? They are on the underside of the offside front inner wing - which I want to remove. Looked from under bonnet but it is not clear what is fixed to the inner wing.
Post #505510 17th Feb 2016 4:46pm
Airbox base, inlet side. Thumbs Up
Post #505511 17th Feb 2016 4:50pm
RichLech
Many thanks for the prompt response.
So how does this affect removal of the inner wing? Do have to dismantle the airbox first?
Post #505584 17th Feb 2016 8:39pm
tobz102
if i remember correctly from installing my safari snorkel, you could simply drill the rivets out and the intake hosing would support the airbox in place whilst you remove the wing.. Though the intake assembly is so simple it might give you more space to just remove it all prior to taking the wing out.
Post #505765 18th Feb 2016 11:13am
