![]() | Home > For Sale & Wanted > [For Sale] New Black powder coated steering guard like urban |
Urban steering guards last about 6 weeks before rust starts to show....mine sux
This has got to be a whole lot better option than a tUrban version. Good luck with the sale. |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
Hopefully as this is anodised and then powder coated
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7944 ![]() ![]() ![]() |
Steel or aluminium?
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
If it's been anodised it will be aluminium.
I may be wrong with the anodised finish then
![]() Just looking it up the original listing it says steel gold zinc plated. |
The yellow finish is usually a zinc passivate. It's quite a good durable finish
Little bump befor eBay. Open to offers
Christian1402 Member Since: 17 Feb 2016 Location: Cumbria Posts: 214 ![]() ![]() ![]() |
If you'd consider posting then I would be interested?
Would be happy to post just not sure how as its pritty heavy and large
A courier would be easiest. Either drop off at a designated shop/petrol station depending on the courier, or they will collect from home/work address
![]() Damage is the only worrying factor. It would have to be well packaged? |
Just managed to weigh the guard and comes in at just shy of 13kg and have had a postage price of £30 which considering the weight I didn't think it was that bad.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Where in the midlands are you and does it have its fixings? Mike
Based in Worcester.
Sorry no fixings |
landybear Member Since: 18 Oct 2015 Location: Tamworth & Worcester Posts: 134 ![]() ![]() ![]() |
Do you know what the make is? Suspect I'm not a million miles away from you (central Worcester) 2003 Defender TD5 Hardtop (current - work in progress)
2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous) Disco 2 Landmark 2004, 2001, 2002 (Previous) Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous) Defender 110 300tdi 1993 (Previous) Range Rover Vogue 4.6 - 2001 (Previous) Freelanders TD4 (2001 3 door & 2002 5 door) Previous 90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others |
