Home > Maintenance & Modifications > WIPAC LED Light Covers
Edzi
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Alaska White
Greetings All,
I had a full set of WIPAC LEDs fitted, along with a pair of black JW Speaker Evo 2s by the folks at TMD. Superb lights, big difference in brightness, coverage and highly recommended.
These are the WIPACs http://tmdtuning.com/shop/led-lighting-set-wipac-2/
I'm in two minds over the look of these on my white 90, so have been toying with the idea of getting some black plastic lamp guards, probably the KBX ones, but also considering the more common crisscross design too, just to tone down the shiny look.
Does anyone have these fitted, ideally to a white Defender? If so, would you mind sharing a few pictures? Close ups and wider shots showing the truck would be ideal. I was also wondering if fitting them would drastically lower the light output as they will in parts cover up some of the LEDs??
Cheers,
Edzi
Post #504558 14th Feb 2016 11:27am
K9F
I had the plastic ones, they are what they are 'cheap and cheerful' they lasted not very long before they faded and became very brittle. Spend a bit more and get metal ones would be my advice. Sorry the Defender is not white, not my colour.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #504582 14th Feb 2016 12:52pm
Edzi
That's most helpful, thanks Smile
May I ask where you got your metal ones from? Also, do they just screw in to the lights? One of them looks like it's screwed in to the body?
Thanks Smile
Post #504584 14th Feb 2016 1:01pm
K9F
These guards were made by an Italian company called Corsetti and were provided by LRS Offroad. I believe due to supply issues they are now manufacturing their own in the UK. The front guards you do need to drill. With regards to the rear upper ones these are fitted with no drilling, the lower ones needed drilling and Rivnut fitting but also with a minor manufacturing change could have been made to be fitted without the need to drill. This may well have been updated perhaps? Ring Derrick at LRS and ask if you are interested?
http://www.lrsoffroad.co.uk/exterior-parts.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #504588 14th Feb 2016 1:10pm
Edzi
Thanks Smile Much appreciated.
Post #504593 14th Feb 2016 1:19pm
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
On a white one...
Have had them fitted for about 8 months and even under the harsh Botswana sun, have not faded nor become brittle.
But as K9F pointed out, they are 'cheap & cheerful', so if they last a couple of years, I'll still be happy.
The Corsetti ones do look much stronger & longer lasting, but I did not like the look of them, too chunky for me.
If a manufacturer made ones that looked the same, in metal and mounted with the light mountings, I'd certainly look at getting a set (but with the Pula @ around 22 to the Pound, doubt I could justify that expenditure)
Looking forward to see what you end up going with... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #504914 15th Feb 2016 4:30pm
Edzi
That's great; thank you Smile Shall keep you posted. I do prefer then gentler design of yours or the KBX ones.
Post #504917 15th Feb 2016 4:45pm
Bushpig
forgot to add...
Got mine from Bowers, link herehttp://www.bowerspartsonline.co.uk/vehicle...uardgrille
Had to slightly modify the 95mm ones, but the 73 ones fitted perfectly. Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #504920 15th Feb 2016 5:01pm
Edzi
Cheers Smile
Post #504924 15th Feb 2016 5:32pm
ericvv
A bit Off Topic .
If I would have a Defender with standard lights as opposed to the SVX version, I would have installed these genuine light guards here. Always liked the look of those. But then again, they would not have been available here as they are illegal in Switzerland. Maybe because they rust which probably is also illegal here.
Rolling with laughter
Some people buy them in France and do install them anyway without issues.
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #504962 15th Feb 2016 7:32pm
Edzi
I do like them but think they work better with a classic looking Defender Smile
Post #505001 15th Feb 2016 8:40pm
Screbble
ericvv wrote:
A bit Off Topic .
Eric
If rust were illegal then I'd be locked away for ever Rolling with laughter
I have those fitted Eric, and yes it doesn't take much for rust to set in (matches the rest of the truck!).
You've prompted me to get them off, get them painted, and to isolate and coat those stainless fixings. My anorak is at the ready.
Something for Spring Whistle
Back on topic now - nice looking lamp guards Mal - great attention to detail as always Thumbs Up
Post #505084 16th Feb 2016 7:37am
diggers1981
2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Just to let you know KBX Light guards will not work with the Wipac Fog & reverse lights. Just so you don't go buying them and then realising after.
Post #505844 18th Feb 2016 3:44pm
Edzi
Thanks for this. Had sent off an email asking several days ago and never heard back. Much appreciated Smile
Post #505850 18th Feb 2016 4:08pm
