Home > Maintenance & Modifications > Cut out switch
toby9946
United Kingdom 2015 Defender 90 Puma 2.2 Landmark LE Corris Grey
Cut out switch
Hello All
I've been toying with the idea of fitting a hidden cut out switch somewhere in the cab.
I know this is probably a very silly question but presumably without the fuel pump going the beast won't start/run?
I would go and pull the fuel pump relay out and try it but Im concerned the system may need bleeding afterwards?!
Appreciate some may not want to post on an open forum so feel free to PM me!
Thanks in advance! Toby -2015 Defender 90 XS Landmark-
Post #503688 11th Feb 2016 10:35pm
grafty99
You have a pm 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #503730 11th Feb 2016 11:58pm
Cupboard
Don't 2.2s have a mechanical fuel lift pump? 2.4s do which is why you can't do the bleed thing like you can with a TD5.
Post #503884 12th Feb 2016 2:04pm
2.2 reverted to an lp pump in the tank.
Post #503892 12th Feb 2016 2:20pm
