Home > Technical > Oil code on scanguage? what does it mean.
Stacey007
Hello
I have this message on the gauge, looked up on
http://www.datsc.com/tabid/122/OBD-Error-C...fault.aspx
however I don't think its an error as such? do I just need some oil? No other lights on and drives as normal. I guess without the code reader I would be none the wiser at this point but I would like to know what it is.
Thanks
Post #503607 11th Feb 2016 8:36pm
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
This is interesting Stacey007
My 90 has done approx 2900 miles. I had oil service flash up on the odo display.
When I called the Stealers to book it in they said it does not need one, the supplying dealer should have zero'd this.
This could be unrelated but that maybe what you have found, this oil service code. Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #503623 11th Feb 2016 9:04pm
Cupboard
It's a user settable alarm in the Ultraguage (it's not a Scangauge, that's something different).
It is there to remind you to change the oil after however many miles, you can set it to whatever you like or disable it. Nothing to do with the Defender.
Post #503664 11th Feb 2016 10:00pm
Stacey007
Many thanks
sorry I got the unit name wrong I looked at both back when I bought this but liked this as its smaller.
I will have a look at the settings and change them Smile
Thanks
Post #503670 11th Feb 2016 10:10pm
