Home > Maintenance & Modifications > Crack where roof meets windscreen
Simon27
Scotland 2009 Defender 90 Puma 2.4 SW Tamar Blue
Noticed today a crack in the roof metal, right above where it is joined to the windscreen frame.
Not sure if you can really see it in the photo, but it must be at least 1mm thick in places and about 2 or 3 inches long. What can I use to patch this? Not too worried about looks at it's so high up.
Post #501913 7th Feb 2016 11:08pm
jimbob7
Any mastic will do but not silicone based as you can't paint anywhere near it afterwards.Sikaflex or tiger seal are popular automotive brands. Pov.spec,ftw. 2006, 110,TD5.
Post #502057 8th Feb 2016 11:50am
I'm not seeing a crack from that photo, it actually look more like an impact from a stone or other object?
Got any more photos?
Post #502093 8th Feb 2016 1:34pm
Martin
Site Admin
I've enlarged the pic  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #502094 8th Feb 2016 1:37pm
jimbob7
Bridgestrike,by the look of it, Shocked .....hope he reported it!! Pov.spec,ftw. 2006, 110,TD5.
Post #502098 8th Feb 2016 1:46pm
Simon27
It's definitely a crack, I don't remember hitting anything! I've got some scratches from bushes but nothing hefty to cause this.
Should I be worried about it structurally?
Post #502375 8th Feb 2016 10:45pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
If I zoom in I think I can see the rusty edged crack.
But are you saying that there is a trick of the light or something and NOT what appears to be a very obvious impact area with dent and loss of paint? Most people will naturally question whether they are linked.
edit: added marked up photo
Post #502390 8th Feb 2016 11:07pm
mk1collector
I think what looks like an impact is just where the light is hitting a very poorly done spot weld from the factory. The two bits of panel were obviously not properly together when welded which I probably the reason your now seeing it crack, if you were to weld it the roof would need painting so if it's just the possibility of water getting in your worried about then a tiny bit of sikaflex will sort it. If it's still under warranty you could let the dealer sort it. Ray
My build thread
Post #502428 8th Feb 2016 11:35pm
mk1collector
Just looked at the pic again and re-read the first post and have now seen the crack Embarassed I'd just put sikaflex in that too but clean it out thoroughly with something like white spirit first. Ray
My build thread
Post #502433 8th Feb 2016 11:39pm
Philslandy
Germany 2002 Defender 110 Td5 SW Epsom Green
Nothing to wory about, i haven`t seen a Defender without a crack in that place.
It is the mastic that separates from the car Body.
Just take some waxoil and apply it with a brush or your finger in the crack - best to do when summer nice and warm.
Thumbs Up
Post #502505 9th Feb 2016 8:43am
Thanks to apt100 I can now see what the OP was talking about but not making that obvious!
It does look like the classic crack you can sometimes see around the guttering. Not sure if it's down to age related shrinkage or a more mechanical separation, or even a combination of them both.
Advice above seems correct - clean out and reseal with a good quality sealant. I'd actually rake it out a bit to get a larger surface area and deeper void for the new sealant to sit in.
I would think that Waxoyl was not appropriate unless you used one of their underseal products.
Post #502670 9th Feb 2016 3:59pm
Happyoldgit
Time for me to step in and say they all do that sir Steve.
http://forums.lr4x4.com
Post #502867 9th Feb 2016 10:15pm
Simon27
Thanks Supacat, that's exactly what the issue is! Glad it's a known issue, I just couldn't find any reference to something like it before.
This might even fix the water coming in through the top of the door which I just assumed was the door seal.
Post #502881 9th Feb 2016 10:35pm
dorsetsmith
291 sikaflex
it can be painted over
Post #503006 10th Feb 2016 9:41am
Simon27
Sealant ordered, just need to clean and dry out the crack now. Thanks for all your advice!
Post #503712 11th Feb 2016 11:08pm
