![]() | Home > Maintenance & Modifications > problem fitting roof rack |
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 ![]() ![]() ![]() |
I had the same problem with my 110. Adjusting the height of the doors by dropping the hinges slights sorted it out without any leaks
![]() 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
stricko Member Since: 30 Nov 2015 Location: East Sussex Posts: 120 ![]() ![]() |
Thanks - is it easy to do? ---------------------------------------------------------------
Yeah, a doddle. Only loosen of the torx head bolts enough to enable moving the door up and down. I used a wide wooden spatula as a lever underneath the bottom of the door to assist in moving it up and down to get it right. You might have to adjust the door catch to suit the change in height also
All done - cheers
Excellent
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 210 ![]() ![]() ![]() |
Since you lowered the doors what are your shut lines like now? I had the same problem with my 90 with the drivers door. I dropped the door a tad but not too much but also ground a little off the bracket. In the end you only need a fag papers width after all. The passenger side wasn't a problem as it had 6mm clearance, that's build quality for you eh?
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 ![]() ![]() ![]() |
Out of interest, what make is the rack?
Hi apt100, mine is a Front Runner rack, but I don't blame the rack itself, when you look at the difference in height from the two gutters and corresponding doors the blame sits squarely (or lopsidedly in this case) with how my 90 was put together. Funny thing is that the doors match up with the body contours fine.
Thanks for the reply.
You would still like to think that a rack being sold for a Defender would take into account the legendary build quality ![]() (I once bought an Halfords rack for a Vectra that rubbed the top of one of the doors. After a bit of whinging and sulking from the Manager I got a refund. I then shelled out on a genuine Vauxhall one that fitted much better with loads of clearance.) |
As it turned out I only needed to lower the passenger side doors a tiny bit. The driver's side were fine.
The doors all shut fine. I had to alter the catch slightly on the rear passenger door, the front was ok. The roof rack was from MM-4X4 It was the cheapest priced one I could find (at �444 + 56 for the ladder) It needed to be self assembled (I dont know if others do or not?) Its very solid once built and I have been up on top and it supports my weight ok. Here is a pic. ![]() Click image to enlarge --------------------------------------------------------------- |
Alls well in the end then. I had to assemble my frontrunner rack, it looked more like a bedframe when it was assembled, I hadn't thought about how big it would be.
Your rack looks very snug atop your 110.....enjoy ![]() |
