Home > Td5 > Changing ECU
miker
Changing ECU
I currently have a 1999 TD5 with a 15P engine (swapped due to the old engine droppping it's timing chain).
I have changed to green-top injectors, and had them coded in. The guy that coded the injectors in for me, and Tazz from here, have both commented that the ideal would be to have a later model ECU. Thi would enable it to run in EU3 mode and allow easier updates and mapping in the future.
As I currently have an old, non-programmable ECU, what can I swap to? The guy that will do the coding for me has the proper diagnostics kit. Can I throw a disco2 in there without any issues?
Mike
Post #500606 4th Feb 2016 9:38pm
MadTom
Look for NNN000120, NNN5000020 or NNN500250 ECU, these are flashable ECUs for TD5 with manual gearbox. The rest is only uploading the right map in the ECU. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #500751 5th Feb 2016 9:58am
miker
Perfect, that's what my research had lead me to believe as well. Cheers!
Post #500962 5th Feb 2016 7:43pm
MadTom
There were also some 15P (EURO3) engines with MSB type ECUs, but I have never seen one myself. And software in NNN ECUs is a bit better. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #501138 6th Feb 2016 9:19am
