Home > My Defender > New tires
kjmeijer
Netherlands 2016 Defender 110 Other SW Galway Green
New tires
After 93.000 km with the old AT's the new BFGoodrich All Terrain T/A KO2 LT235/85R16 are fitted. Very Happy
 2021 Defender 110 D300 HSE
Post #500472 4th Feb 2016 4:52pm
JOW240725
Great looking truck!! Thumbs Up
How do the new KO2's compare?
Post #500502 4th Feb 2016 6:31pm
geobloke
Sweet...
For new tyres there are a lot of weights on those wheels...
Post #500611 4th Feb 2016 9:41pm
p_jeeeee
Belgium 2007 Defender 90 Puma 2.4 SV 90 Caprice
so much better!
Post #501603 7th Feb 2016 12:27pm
Thon
That's exactly the set-up i'm going to use. Currently gathering Wolf wheels of the correct type.
I used to have the previous BFG AT tyres which were great and hard wearing. Glad to hear that these are even better!
I'm also interested as to why you chose the standard 235/85 size when so many go up to 255 and 275 width. Personally I am going to use 235/85 because I don't believe that wider is necessarily better.
Post #501661 7th Feb 2016 2:05pm
Cuthbert
Cosmetically your vehicle would look a 100% better if you painted those silver balance weights on your wheels black to match the wheel rims? Those silver weights just draw the viewers eye vfor the 'wrong' reasons.
Post #501769 7th Feb 2016 6:16pm
kjmeijer
Thanks for the response!
After a few days driving with the new tires there is not much difference compared to the old AT's. Sometimes it looks the ride is a bit softer but I am not sure. There was a lot of rain over here (not at much as in the UK) and I drove in deep mud a lot: traction is perfect.
I have been thinking about wider tires but this size has done the job for years without any problems and for fuel consumption & noise I think these are best. They also add a "traditional look" to the Defender.
Painting the silver balance weights is the next thing to do! Wink 2021 Defender 110 D300 HSE
Post #502023 8th Feb 2016 10:22am
The next thing to do is take the truck back to the tyre depot and rebalance the Front Drivers side the balance position is just plain lazy Banging Head
Post #502131 8th Feb 2016 2:53pm
kjmeijer
I am sorry but I do not know what you mean with "he balance position is just plain lazy." Could you explain? 2021 Defender 110 D300 HSE
Post #502154 8th Feb 2016 3:52pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
could be that if he had turn the wheel 180°, there was a lot of less wheight
Regards
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #502163 8th Feb 2016 4:22pm
Yes that and the fact the tyre appears to be balanced in two separate fields (looks like 2 x 30g/35g then a 10g further round) its a bugbear of mine
Post #502202 8th Feb 2016 5:36pm
