Home > For Sale & Wanted > [Wanted] Anyone got a flatbed trailer they'd rent to me for
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
I'm after a flatbed trailer, with or without sides. Need to bring three pallets up the road. Needs to be 12ft minimum
I'm happy to pay you to rent the trailer and happy to leave a deposit in case of damage.
Ideally somewhere between inverness, Aberdeen and Dundee would be good.
I'd like to collect on 13 Feb and drop back off on 20th.
Thanks
Post #500059 3rd Feb 2016 8:47pm
spags
Scotland 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
I have a large Ifor Williams twin axle flat bed, tilts and has drop sides that could do the job. Is it for private use or business as that dictates need for tacho and operator license? Also important that it is loaded correctly and strapped down to meet any VOSA inspection. (your safety and that of others)
Located at Tulliallan between the Clacks and Kincardine bridge.
Overall length inc of drawbar is 6m
Width Platform 1980mm/6�5��
Length Platform 4870mm/15�11��
Loading Height 640mm/2�1��
Internal lashing rings
Gross weight inc payload is 3500kg
PM me for more info and direct contact mobile.
John
Post #500129 3rd Feb 2016 10:59pm
I.AM_a driver
Scotland 2002 Defender 90 Td5 CSW Oslo Blue
If you're lucky you may find that a local farmer has a flatbed trailer you might be able to borrow, if you can't find one suitable on here. Any farmer that moves hay bales around will probably have one- I buy hay/straw from a farmer & he uses a 16' Ifor flatbed to deliver. Mark S
CONVOY for HEROES
www.facebook.com/convoy4heroes
www.lothian4x4response.org
Td5 90
Thread in 'My Defender' Forum
Post #501079 5th Feb 2016 11:29pm
allyjbull
United Kingdom 2013 Defender 110 Puma 2.2 USW Santorini Black
Trailer hire
Hi Mike
Have you tried Whiteside Trailers at Airntully near Perth? I've hired horse boxes off them a few times and I'm pretty sure they have flat beds.
Might be a bit out of your way but worth a punt if you're stuck.
Allan
Post #501124 6th Feb 2016 8:43am
