Home > Puma (Tdci) > VCV removal and replacement
Coolcamper55
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
As some on here will be aware, I have been struggling to get my vehicle running. Trouble started last August and has got steadily worse
I replaced the vcv in September last year but suspect the pressure valve on the rail was gone but did not replace that at the same time. I want to be certain the vcv has not gone again.
I have had issues with getting the valve programmed and have now spent £300 or so with diagnostics without a solution.
I did change the valve before but cannot for the life of me remember how I got the bolts out.
Is there a trick or a combination of tools that allow you to get through the forest of cables and pipes that seem to block the way. Do I have to take out components.
Really stumped Tommy
110 XS TDCi
Post #497054 27th Jan 2016 5:23pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
It's a real pig to get to. I think when I did mine I used a combination of long reach ball end allen key together with 1/4 inch square drive socket and knuckle socket. Lots of swearing and bloody knuckles too.
Post #497073 27th Jan 2016 6:25pm
Coolcamper55
Done, 4 hours.
Found the best way for me was using a flexible drive to bend round the pipes, an extension 1/4 bar, universal joint and small ratchet.
Thanks Tommy
110 XS TDCi
Post #498716 31st Jan 2016 6:16pm
Did the change do the trick and solve the problem?
Post #498725 31st Jan 2016 6:24pm
Coolcamper55
Combination of things I think. CHT and VCV changed and its looking positive. When I get the pump learn and pilot correction carried out (hopefully tomorrow) I will be more comfortable undertaking any serious journeys or towing. Tommy
110 XS TDCi
Post #498743 31st Jan 2016 7:10pm
