Home > Puma (Tdci) > Gear change, First to Second 'nick'
Page 4 of 4 <1234
agentmulder
Kuwait
Zero change with new clutch/bearing, new clutch hydraulics or gearbox oil. Solved the bowel problem, working on the consonants...
Post #530567 11th May 2016 9:13am
ter11
Switzerland 2007 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Bad news, but much appreciated!
Ter
Post #530571 11th May 2016 9:40am
MartinK
I do think mine is improving with age.
Just started driving her again ... been garaged since October!!! (other projects/pressures, then a cycling accident put me out from driving for 2 months).
At 30,000 miles, with the LTB00585 mod done, and now 2 changes of gearbox oil, she seems a bit better. Still needs to change 1-2 slowly and deliberately... but getting better
Only time she's bad is when cold, on a hill start, when you need to be quick 1-2 to keep momentum...
Bizarre, but 1st time I changed the oil, I used "upgrade" Castrol synthetic oil,... but most recent oil was "carplan" cheap stuff (still with correct properties) from Halfrauds... I think the cheap stuff may help!!! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #530572 11th May 2016 9:48am
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Ditto what AgentMulder said.. I changed the clutch plate and cover, bearings, fluids, gearbox output shaft.. Still the same cr4ppy MT-82 we've all come to loathe and hate! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #530713 11th May 2016 7:21pm
Erik256
Estonia 2007 Defender 110 Puma 2.4 SW Keswick Green
Same here. Changed the clutch and main bearing, installed the shims, tried different oils (Motul 3000) and additives (Ceramic Power Liquid), adjusted clutch travel and tried driving with or without rubber mats. No real difference.
I Read from here (http://www.defender2.net/forum/post87098.html) that Ford recommends a special friction modifier for Mustang gearboxes (they also use a version of MT82 and have reputation for poor shifting). Haven’t yet tried this, so maybe worth a try. Tough I haven’t seen the additive for sale on this side of the pond.
Post #530974 12th May 2016 12:46pm
Pickles
Pickles wrote:
Don't think any gear changing "method" will make any difference,...it's obviously something to do with the design & working of the syncro going into 2nd gear.
Pickles.
Like I said,..basically, "It is what it is",,,
Pickles.
Post #531157 12th May 2016 11:29pm
YOLO110
Australia
Yup!
But they don't all do it! Whistle YOLO... You Only Live Once...
Post #531161 12th May 2016 11:43pm
agentmulder
Kuwait
Ok, sooooo, check it out if you haven't already:
http://www.defender2.net/forum/post537600.html#537600
edit> just realised that thread is a sticky, very likely you've all read it... Whistle
Anyway, FWIW in my case it's been helpful - and I mean that, it's not just me justifying a morning's work Wink Rolling Eyes Solved the bowel problem, working on the consonants...
Post #537601 5th Jun 2016 4:57am
agentmulder
Kuwait
OK, spent a tank of diesel so far with the insert mod.
Seriously better.
Took a while to get used to it actually, just to plonk it into second directly. But of the I dunno, hundreds of changes (?), I recall one hands worth with any hint of a 'croik' noise, and even then it was minimized. For me and my vehicle, I'd consider this case closed (YMMV). Solved the bowel problem, working on the consonants...
Post #538012 6th Jun 2016 8:30pm
Page 4 of 4 <1234
