Home > Puma (Tdci) > removal or rear speaker trim panel
Vitesse
Hello,
sorry for the daft question, but how do you safely remove the rear plastic trim that holds the speaker. I need to gain access to the wiring for the rear lights etc...
Thanks,
Vitesse
Thumbs Up
90XS SW 2015 90 XS Santorini Black
Post #494472 20th Jan 2016 6:05pm
RRUK
First you remove the upper rear trim panel that surrounds the quarter light windows, to do this simply grab near the door and pull into the vehicles towards the front seats and the metal springs clips (2 on each panel) will undo. Most likely one or both will be found either on the body work afterwards or on the back of the trim panel.
Then it is easy to access the speaker panel and wrestle it out too, AFAIK it's not held in place by anything. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #494478 20th Jan 2016 6:41pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Lower panel is held in place with three plastic screws with heads made of cheese. It's also likely that the two clips holding the top panel will deform enough not to re-seat properly afterwards but these are pennies each from Duckworths Thumbs Up
Thinking about it you might get away without taking the top panel off 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #494498 20th Jan 2016 7:48pm
Vitesse
many thanks! That's great. Thumbs Up 2015 90 XS Santorini Black
Post #494643 21st Jan 2016 9:08am
