Home > Puma (Tdci) > Heater door mirrors
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
Heater door mirrors
Hi,
I have some heated door mirror elements for my Defender. Can I connect them into the relay for the heated rear screen? If so, does any one know which coloured wire for the live supply? I,ll put an in-line fuse in for them.
Thanks.
Post #43595 26th Oct 2010 8:27pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
They dont take much current.
The heated rear window supply is 20A.
Possible to splice into the heated rear screen cable and fit an in line fuse, according to the diagram the + supply to the HRW is white & black.
Post #43597 26th Oct 2010 8:40pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
HI bosun,
where did you get the elements from?
Post #43769 28th Oct 2010 12:03pm
Paul_1978
You can get the elements from eBay, cost about �17 for the pair.
Bit of a fiddle fitting the, devon 4x4 did a write up on the subject.
I ran the cable down the arm and base so it cant be seen.
Works a treat now.
Post #43780 28th Oct 2010 12:40pm
Bosun
HI bosun,
Hi Nicks,
Got them from Scorpion when they were in business. Fitted a treat on my TD5, just haven't got around to fitting them on the TDCi yet. Just thought the heated rear window route might be easier. Used a switch in the spare aperture in the centre console before. Took some time routing the cables and connecting to the LR switch.
Bosun
Post #43785 28th Oct 2010 1:13pm
nicks
What about conecting them so they are on constantly with ignition. The ones on the wifes Audi are on all the time, keeps the rain of them.
Post #43786 28th Oct 2010 1:16pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi All,
The Devon 4x4 Guide has gone. Well I haven't been able to get to it. Says " File no longer on server".
How do you get the wire into the cab? Any advice or pictures would be much appreciated. Bow down
Post #43907 29th Oct 2010 6:47pm
WarPig
Post #43908 29th Oct 2010 6:55pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
WarPig wrote:
Hopefully this guide works
http://la7dja.org/defender/mirror-heating/
Thanks Thumbs Up.
I'm planning to do this mod also, on both my Td5 and Puma Defenders Mr. Green.
Now I have to source those heating elements Wink
Post #44078 1st Nov 2010 10:12am
Paul_1978
Ive fitted both heated mirrors onto my 90, the hardest part is feeding the cable through the bulkhead and through the spring part on the mirror.
Post #44090 1st Nov 2010 1:16pm
kljw
Hi
do you have pictures of how you any of you completed the task. i have downloaded the link info, but an interested in seeing how you chaps got on.
thinking of doing this to mine. Cheers
keith
puer claudius
Post #57377 7th Feb 2011 2:23pm
nicks
i feed my cables behind the front door seals and connected striaght to the heated front screen terminals.
Post #57422 7th Feb 2011 4:50pm
