Home > My Defender > Keswick V8 90 Soft top
Page 6 of 19 <123 ... 567 ... 171819>
L110CDL
Same thoughts as you GREENI Thumbs Up
Clayton.
Post #509787 1st Mar 2016 10:49pm
CY88
1986 Defender 90 V8 Petrol ST Keswick Green
Proper top-down today Wink
Post #513475 12th Mar 2016 11:31am
Pickles
A wonderful build,...well done.
But, from the land of V8s, ...when's the exhaust happening?
I would suggest twin 2.5" pipes, exiting from the rear, not from the mudflap area, but underneath the rear cross member, about a foot in from each side with chrome tips on the end of each pipe. Initially ya wouldn't even have to worry about headers, just connect to standard manifolds, it'd still sound well & truly like a V8.
Top job, Pickles.
Post #513677 12th Mar 2016 9:22pm
CY88
Cheers Pickles. I went to see a guy recently who I'm going to ask to sort out the engine. At the moment it's running the original stromberg carbs, and some strange set up that vents some of the (possibly fuel rich) exhaust back into the combustion chamber (ever heard of that - apparently it was common on the early V8s?). The latter gives it a funny noise on tick-over that doesn't sound very v8.
So I'm hoping to change the strombergs for better ones, and will do the exhaust at the same time. Fingers crossed!
Post #513738 13th Mar 2016 1:00am
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
Sounds like the Early Detox system you still have fitted, was an emission control pre SU or Injection... I had this fitted to RV8 in 2a Lightweight back in the day...
Your Poor V8 with its detox gubbins and Carb restricture plates you probably only in the region on 85bhp!!
Better to put an Elberbrok/Weber kit on or injection Smile
Andy Working towards Carry on camping!
Post #513787 13th Mar 2016 9:52am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Fantastic build and one I am contemplating, Keswick Green, the best colour IMHO.
Did you get the doors to seal properly in the end?
Post #513829 13th Mar 2016 12:06pm
CY88
Andy
This is just what I'm going to do, probably the Weber kit, and like you say, dump all the restrictions. Thumbs Up
Post #514013 13th Mar 2016 10:53pm
CY88
Yup, doors were sealing a treat, although now I've fitted the new hood frame this weekend I'm going to have to go through the whole process again. Can't believe the gap in the top of each door corner that'll need a big gob of caulk shaped into it.
Bit of an update from the weekend:
Before fitting the new frame and canvas, I wanted to take the opportunity to have a good airing in superleggera mode Thumbs Up
And then to fitting the new canvas...
Sailing Tom asked whether I'd considered the heavy duty frame (like he had and PJB has), but I had an original seat belt bar which I wanted to keep attached (for when the frame is off like above), and to save faffing around with all the bolts and seat belt anchorages, I just went for a new land rover spec galvanised frame which should come apart nice and quick.
Also got the straightforward canvas hood instead of the mohair, nice and simple again, and lots of different ways that you can "wear" it going forward Smile
Cheers everyone!
Ps. Don't worry Pickles, engine and exhaust updates will be coming soon I promise!
Post #514016 13th Mar 2016 11:13pm
Pickles
CY88 wrote:
Andy
Edelbrock/Holley etc sounds good, but I don't know anything about a "Weber Kit",.....so what carby is that, & what does it look like? (Obviously I know what a Weber is, but I'm just curious to know what sort of Weber & manifold would sit on top of a V8?)
Pickles.
Post #514022 13th Mar 2016 11:52pm
CY88
Here's a link to the Weber v Holley dilemma. Weber seems to be better for 4x4s because the float levels are more suited to driving on an incline?
http://www.v8tuner.co.uk/faqs.php?id=6
RPI engineering do the "Weber 500 carb kit" aimed at Rover V8s, although their website seems a little out of date. They too seem to suggest the Weber is better for off road applications. I think that the name "weber" is a branding exercise in the UK.... the same kit would be branded Edelbrock elsewhere (hence the Edelbrock stickers in the photos).
http://www.v8engines.com/faq-carb.htm
Post #514096 14th Mar 2016 10:36am
pjb
looking cool Thumbs Up 2020 P300 HSE
Post #514101 14th Mar 2016 10:43am
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Looks lovely.
I had an Edelbrock 500 on my 3.9 and I loved the sound but it did occasionally stall on steep inclines off road. I bought a set of off road springs for the needles that were supposed to help, but never got around to fitting them.
Post #514173 14th Mar 2016 1:50pm
Pickles
No worries.
Never heard of a Weber 500,...now I have, & it sounds Ok for your use.
Holley would be much more well known in Aus, & I was going to suggest a 500,...Edelbrock is of course very well known for manifolds etc. If ya're going to do this, that exhaust will be more important than ever??!!
Also, I don't know what sort of use you have in mind for this machine, but if it's predominantly road use, have you considered lowering?
Pickles.
Post #514374 14th Mar 2016 10:25pm
CY88
Inigo wrote:
Looks lovely.
That's useful to know, cheers!
Post #514471 15th Mar 2016 10:09am
CY88
Pickles wrote:
No worries.
Pickles.
Ha I know I know - exhaust is key! I'll be sure to post some before and after sound clips when its ultimately fitted!! Thumbs Up
But ... lowering a Defender is sacrilege!! (IMHO) Razz There are other toys for the road Wink
Post #514473 15th Mar 2016 10:14am
